Joined: 10/5/2015(UTC) Posts: 47  Location: Norman, Oklahoma
I have a question. I am using the chroma key feature for weather. However there is some pixilation always around the person on the chroma key. Its not super noticeable but it is noticeable. I have it set using auto chroma key and I have played with the filter setting some and evening the gain on the actual capture device. How can I get a smoother chroma key? Anyone have any advice or what setting could I be missing. I know even on some essentially free products the chroma key looks better. I love vmix and have been using it for awhile. This is my first real issue I am having.
Thanks!
William
Joined: 1/13/2010(UTC) Posts: 5,322  Location: Gold Coast, Australia Was thanked: 4726 time(s) in 1618 post(s)
Hi William,
Can you create a snapshot using the camera icon in vMix of the key and post it so I can take a look?
Thanks,
Martin vMix
Hi, Sure here is one example... see the pixilations round the body and head. ccolewilliam attached the following image(s):  vMix Capture 04 October 2015 21-27-07.jpg (48kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
A couple thoughts (might not be related to this issue, but take with a grain of salt)
A down light or back light will help separate your subject from the background. Try to space the subject 4-5' away from the green screen. Good even lighting on the screen too is a must.
I noticed some pixelization in more than the chroma key in you photo. What resolution is vmIx set for? Camera resolution? Graphics resolution? The higher the better, if your PC & GPU can support it.
The video artifacts could be camera resolution rather than chroma key.
Hope this helps.
- Tom
