ccolewilliam
#1 Posted : Monday, October 5, 2015 8:11:54 PM(UTC)
ccolewilliam
I have a question. I am using the chroma key feature for weather. However there is some pixilation always around the person on the chroma key. Its not super noticeable but it is noticeable. I have it set using auto chroma key and I have played with the filter setting some and evening the gain on the actual capture device. How can I get a smoother chroma key? Anyone have any advice or what setting could I be missing. I know even on some essentially free products the chroma key looks better. I love vmix and have been using it for awhile. This is my first real issue I am having.
Thanks!
William
#2 Posted : Monday, October 5, 2015 9:39:33 PM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
Hi William,
Can you create a snapshot using the camera icon in vMix of the key and post it so I can take a look?
Thanks,
ccolewilliam
#3 Posted : Monday, October 5, 2015 10:38:39 PM(UTC)
ccolewilliam
Sure here is one example... see the pixilations round the body and head.
ccolewilliam attached the following image(s):
vMix Capture 04 October 2015 21-27-07.jpg (48kb) downloaded 7 time(s).
sinc747
#4 Posted : Tuesday, October 6, 2015 4:30:23 PM(UTC)
sinc747
A couple thoughts (might not be related to this issue, but take with a grain of salt)
A down light or back light will help separate your subject from the background. Try to space the subject 4-5' away from the green screen. Good even lighting on the screen too is a must.
I noticed some pixelization in more than the chroma key in you photo. What resolution is vmIx set for? Camera resolution? Graphics resolution? The higher the better, if your PC & GPU can support it.
The video artifacts could be camera resolution rather than chroma key.
Hope this helps.
- Tom
Similar Topics
Chroma Key access through API (Feature Requests)
by michaelthomasbrennan 4/3/2026 12:45:52 AM(UTC)
chroma key - can't remove orange (General Discussion)
by xxsuna 11/25/2022 6:51:23 PM(UTC)
CHROMA KEY IN ATEM OR VMIX? (General Discussion)
by curiousgeorge 4/15/2022 3:12:17 PM(UTC)
How do I chroma key two different cameras in ATEM MINI? (General Discussion)
by curiousgeorge 4/10/2022 4:42:33 PM(UTC)
CHROMA KEY IN ATEM MINI PRO ISO OR VMIX? (General Discussion)
by curiousgeorge 4/10/2022 10:50:27 AM(UTC)
Chroma Key on Video file (General Discussion)
by Victoryindy 6/2/2021 3:21:43 AM(UTC)
Chroma key functions in shortcuts and API (Feature Requests)
by Mathijs 5/22/2021 2:16:56 AM(UTC)
Chroma Key: green contours while using a blue screen (General Discussion)
by JoostH 4/22/2021 6:40:00 PM(UTC)
Chroma Key distortion issue? (General Discussion)
by Karsten 11/13/2020 12:23:12 PM(UTC)
Chroma Key stays Green (General Discussion)
by mikel2051 9/17/2020 4:33:19 AM(UTC)
chroma key question (General Discussion)
by danlwil 8/29/2020 7:20:48 AM(UTC)
Chroma Key on vMix Call (vMix Call)
by ribbrat 7/10/2020 10:00:57 PM(UTC)
COME USARE CHROMA KEY E VIRTUAL SET (General Discussion)
by Diegone 9/9/2019 6:05:05 PM(UTC)
Version 22.0.0.51 the chroma key has stopped working (General Discussion)
by rpavanello 3/14/2019 12:40:28 AM(UTC)
Chroma Key suddenly going berserk (General Discussion)
by tlovegrove 5/9/2018 8:12:40 PM(UTC)
Improved Chroma Keying in VMix 22 (Feature Requests)
by waynew 5/1/2018 11:06:26 AM(UTC)
vMix Help - Chroma Key section needs updating (General Discussion)
by sinc747 2/14/2018 11:33:18 AM(UTC)
Invert Chroma Key Mask (General Discussion)
by bobdoyle 12/19/2017 5:20:35 PM(UTC)
Chroma key failure (Hardware Compatibility)
by Berts 10/6/2017 6:43:38 PM(UTC)
Chroma Key (General Discussion)
by ccolewilliam 9/17/2017 9:50:24 AM(UTC)
Chroma Key Bright (General Discussion)
by ccolewilliam 8/24/2017 2:47:10 PM(UTC)
Problem chroma key filter (General Discussion)
by NeObr 3/17/2017 10:57:15 AM(UTC)
ProPresenter 6 to vMix via NDI and chroma key issues (NDI)
by Nick Davidson 2/15/2017 10:51:21 AM(UTC)
chroma key virtual set (General Discussion)
by op music 11/15/2016 6:46:13 AM(UTC)
Razer Chroma Keyboard lights... (Feature Requests)
by ne02005 10/21/2016 1:03:20 PM(UTC)
Chroma key no longer functioning properly after latest update? (General Discussion)
by djevo1 10/17/2016 9:48:36 AM(UTC)
How to crop a Chroma Keyed Camera Shot with an Image Background in a side-by-side Multiview? (General Discussion)
by sinc747 8/31/2016 6:47:17 PM(UTC)
Issue with RGB sliders in Chroma key settings (General Discussion)
by richardgatarski 4/27/2016 4:33:28 AM(UTC)
by ccolewilliam 2/7/2016 2:12:09 AM(UTC)
How to record with chroma key (General Discussion)
by Faamt 6/25/2015 6:34:52 AM(UTC)
