Faamt
#1 Posted : Thursday, June 25, 2015 6:34:52 AM(UTC)
Faamt
I use Vmix 15.0.0.81 on Windows 7.
I try to record my video with the chroma key (green background).
I want to stream my video with one background and, in the same time, record it without background image for futurs mix with others background image.
Do you know how to do that ?
#2 Posted : Thursday, June 25, 2015 9:35:18 AM(UTC)
@ Faamt
Depending on your specific set-up will determine the options and possibilities for you.
To do this within vMix you will need the 4K or Pro Edition with the 'MultiCorder' and/or 'Two External Outputs'
http://www.vmixhd.com/purchase.aspx
Otherwise, vMix only records and streams the same "Output".
Alternatively, you can record your 'greenscreen' footage "In-Cam" if your camera has that capability.
(always a good idea for 'redundancy' if the footage is important to you)
GeorgeR on 6/25/2015(UTC)
