wtmuradiotv
#1 Posted : Monday, June 12, 2017 1:24:04 PM(UTC)
wtmuradiotv
Webcam hardware ....Pretty much have updated webcams and they did all work in vmix at one point of time but it seems as vmix has been updated many times they seemed to not work but one .I have posted this issue before and have gotten nowhere with it .All the cams i run work outside the program but one does run within the program .What can be the issue now i have no clue .The codecs in the system are up to date .Like i said at one point they all worked and seemed to work great till vmix has had updates all but one now work .I have changed around the settings to see if it was the settings but nothing .So why are these cams being blocked and what can be done to fix the issue once and for all ???
#2 Posted : Tuesday, June 13, 2017 12:03:08 PM(UTC)
Just change the video format when adding inputs. Your webcams might not like MJPEG as default format, try the others
Guillaume
mjgraves
#3 Posted : Thursday, June 15, 2017 2:25:11 PM(UTC)
mjgraves
Yes, try other codecs in the video format setting.
In order to allow MJPEG a webcam must be UVC 1.1 compliant.
To allow H264 a webcam must be UVC 1.5 compliant.
wtmuradiotv
#4 Posted : Sunday, June 18, 2017 2:27:37 PM(UTC)
wtmuradiotv
AddNewInput.CVR
The operation cannot be performed because the pins are not connected.
About a year or two vmix supported these now it seems since all the updates this is what i get with the last 3 cams
mjgraves
#5 Posted : Sunday, June 18, 2017 3:10:37 PM(UTC)
mjgraves
wtmuradiotv wrote:
AddNewInput.CVR
What make/model of webcams are you using?
Similar Topics
PTZOptics Cameras Freeze over NDI (NDI)
by fcd 7/23/2025 4:07:59 AM(UTC)
Support 10 Replay Cameras & Flexible Storage (Feature Requests)
by gugacdb 5/30/2025 4:14:03 AM(UTC)
Timecode to Multicorder, Recorder and Cameras Hack (General Discussion)
by nowski 3/30/2025 12:15:01 AM(UTC)
Referece system for 20 NDI PTZ Cameras 2K @ 60 FPS (Systems)
by Bulldog 2/20/2025 9:33:26 AM(UTC)
Help Needed with SMTAV IP PTZ Cameras Positioning Issue (Hardware Compatibility)
by jacan sevada 1/13/2025 12:14:50 PM(UTC)
cameras are not showing in Vmix (General Discussion)
by daclifton 11/18/2024 12:58:52 AM(UTC)
How to record 6 cameras in sync and individually for post editing (General Discussion)
by John Hopkins 11/5/2024 8:26:19 AM(UTC)
NDI Cameras with black input (General Discussion)
by bscarbrough1903 9/2/2024 4:28:50 AM(UTC)
NDI Cameras are showing up as just black on inputs (NDI)
by ab800 8/21/2024 6:32:37 AM(UTC)
Cameras 2-4 ghosted (Instant Replay)
by vjmandala 5/14/2024 2:56:32 PM(UTC)
Troubleshooting CPU overload in Vmix with 3 cameras and Blackmagic capture card (General Discussion)
by GameWithSasha 3/27/2024 8:03:39 AM(UTC)
4 Cameras in USB Hub (Hardware Compatibility)
by elfabe028 2/14/2024 1:20:53 PM(UTC)
Zoom support for Cameras / Calls / Audio Inputs NDI feeds (Beta Discussion)
by AElfTech 10/25/2023 3:12:50 PM(UTC)
Best Cameras for Long Event Streams (General Discussion)
by zachEEP 4/9/2023 4:03:46 AM(UTC)
Cameras Stopped Showing Up (General Discussion)
by spydervenom 3/9/2023 10:48:57 AM(UTC)
vMix and PTZ Cameras info request (General Discussion)
by LuMags 3/6/2023 3:05:09 AM(UTC)
PTZ Optics Cameras & Focus Presets (Hardware Compatibility)
by hparsons 1/25/2023 2:30:28 AM(UTC)
Virtual PTZ movement check - don't move cameras in program by mistake (Feature Requests)
by jeregan 1/20/2023 7:32:02 PM(UTC)
Cameras lagg/drop frames. (General Discussion)
by t_dash 12/1/2022 2:44:09 AM(UTC)
vMix 8 cameras replay on Intel 12900 (Systems)
by tkachuk.alex 8/2/2022 9:13:45 PM(UTC)
Cameras Not Showing Up (Hardware Compatibility)
by CCBC2190 7/29/2022 12:26:56 PM(UTC)
Assistance Needed with Adding PTZ Camera Controller and Three Cameras to vMix (NDI)
by tluttrell 7/11/2022 5:40:27 AM(UTC)
How do I delete the virtual cameras generated by VMIX (General Discussion)
by mengxun 7/7/2022 9:18:03 PM(UTC)
AvMatrix Ts3019 Tally ligths for LDK cameras CCU (Hardware Compatibility)
by Gaizka 5/25/2022 8:54:32 PM(UTC)
How do I chroma key two different cameras in ATEM MINI? (General Discussion)
by curiousgeorge 4/10/2022 4:42:33 PM(UTC)
Shortcut or API call for button "Swap Cameras between Replay A and Replay B (Feature Requests)
by kevev 1/28/2022 10:46:44 AM(UTC)
auto select all cameras for replay (Feature Requests)
by gary_co 11/11/2021 6:45:58 PM(UTC)
Input IP cameras into vMix (General Discussion)
by Simsyuk 10/5/2021 9:19:54 PM(UTC)
I'm trying to switch cameras as overlay via midi, on a desktop capture. How? (General Discussion)
by Trujillo 7/11/2021 9:13:38 AM(UTC)
Need to reconnect cameras each time (General Discussion)
by EGSiegel 5/25/2021 6:00:00 AM(UTC)
