How to record 6 cameras in sync and individually for post editing
Joined: 6/24/2024(UTC) Posts: 11  Location: Missouri Was thanked: 1 time(s) in 1 post(s)
I have no problems with having six PTZ cameras going in vMix via IP using a PTZoptics G4 joystick controller for live streaming. However, I am looking for a way to record those same six cameras individually, in sync, and with intact video feed, not just segments of each as you get when switching between cameras while streaming/recording.
Do I need to look for a specialized DVR or software, or is it possible with vMix? I am hopking for specific hardware / software suggestions and possible tutorials on the subject.
I saw suggestions of trying to run multiple copies of the same program but that does't sound like a good options.
Apparently I am not wording the question correctly for google to be of assistance. I keep being pointed to streaming optioins where the camera feeds are being merged which is not what I am looking for. Vmix already has that covered.
Thanks, John
Do you mean the Multicorder? https://www.vmix.com/hel...dex.htm?MultiCorder.htmlThe multicorder will simultaneously record the inputs you select at the same time as soon as you hit the button. We use it all the time - normally with Davinci resolve's multi-cam editing workflow.
Joined: 11/27/2023(UTC) Posts: 136  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
Use multicorder in vMix, but record on different drive for best results...SSD if you have....use it for quite some time now for Horse racing, 8 cameras, 1 is a drone, and no issues...all day long.....
I see vMix multicorder is only on the subscription based versions. I am running the HD version and was trying to stay away from a subscription based solution.
Originally Posted by: John Hopkins  I see vMix multicorder is only on the subscription based versions. I am running the HD version and was trying to stay away from a subscription based solution. vMix 4K and pro are NOT subscription based ! Max which is same as Pro is but more on a "when one needs it" basis (While subscribed ! ) Check the Comparison table again : https://www.vmix.com/purchase/#comparisontable
Doggy, thanks for the update, I have upgraded to 4k.
