John Hopkins
#1 Posted : Tuesday, November 5, 2024 8:26:19 AM(UTC)
John Hopkins
I have no problems with having six PTZ cameras going in vMix via IP using a PTZoptics G4 joystick controller for live streaming.
However, I am looking for a way to record those same six cameras individually, in sync, and with intact video feed, not just segments
of each as you get when switching between cameras while streaming/recording.
Do I need to look for a specialized DVR or software, or is it possible with vMix? I am hopking for specific hardware / software
suggestions and possible tutorials on the subject.
I saw suggestions of trying to run multiple copies of the same program but that does't sound like a good options.
Apparently I am not wording the question correctly for google to be of assistance. I keep being pointed to streaming optioins where
the camera feeds are being merged which is not what I am looking for. Vmix already has that covered.
Thanks, John
mcollege
#2 Posted : Tuesday, November 5, 2024 8:39:26 AM(UTC)
mcollege
Do you mean the Multicorder?
https://www.vmix.com/hel...dex.htm?MultiCorder.html
The multicorder will simultaneously record the inputs you select at the same time as soon as you hit the button.
We use it all the time - normally with Davinci resolve's multi-cam editing workflow.
Luis70
#3 Posted : Tuesday, November 5, 2024 9:54:41 AM(UTC)
Luis70
Grenada
Was thanked: 11 time(s) in 11 post(s)
Use multicorder in vMix, but record on different drive for best results...SSD if you have....use it for quite some time now for Horse racing, 8 cameras, 1 is a drone, and no issues...all day long.....
John Hopkins
#4 Posted : Wednesday, November 6, 2024 6:34:37 AM(UTC)
John Hopkins
I see vMix multicorder is only on the subscription based versions. I am running the HD version and was trying to stay away from a subscription
based solution.
#5 Posted : Wednesday, November 6, 2024 9:28:12 AM(UTC)
based solution.
vMix 4K and pro are NOT subscription based !
Max which is same as Pro is but more on a "when one needs it" basis (While subscribed ! )
Check the Comparison table again : https://www.vmix.com/purchase/#comparisontable
John Hopkins
#6 Posted : Friday, November 15, 2024 1:13:20 AM(UTC)
John Hopkins
Doggy, thanks for the update, I have upgraded to 4k.
