Joined: 7/4/2015(UTC) Posts: 65   Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
Webcam hardware ....Pretty much have updated webcams and they did all work in vmix at one point of time but it seems as vmix has been updated many times they seemed to not work but one .I have posted this issue before and have gotten nowhere with it .All the cams i run work outside the program but one does run within the program .What can be the issue now i have no clue .The codecs in the system are up to date .Like i said at one point they all worked and seemed to work great till vmix has had updates all but one now work .I have changed around the settings to see if it was the settings but nothing .So why are these cams being blocked and what can be done to fix the issue once and for all ???
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Just change the video format when adding inputs. Your webcams might not like MJPEG as default format, try the others
Guillaume
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
Yes, try other codecs in the video format setting.
In order to allow MJPEG a webcam must be UVC 1.1 compliant.
To allow H264 a webcam must be UVC 1.5 compliant.
mjgraves wrote:Yes, try other codecs in the video format setting.
To allow H264 a webcam must be UVC 1.5 compliant. AddNewInput.CVR The operation cannot be performed because the pins are not connected. About a year or two vmix supported these now it seems since all the updates this is what i get with the last 3 cams
wtmuradiotv wrote: AddNewInput.CVR The operation cannot be performed because the pins are not connected.
What make/model of webcams are you using?
