shd
#1 Posted : Tuesday, August 20, 2013 10:26:48 AM(UTC)
shd
I have question. After i play audio track and click CUT / QUICK PLAY for example on the images - audio track is turning off. Is it possible to add function in software, that audio track will not be disabled after using CUT / QUICK PLAY buttons if newer input dont have any audio embeeded? This would be great. I know that i can use overlays, but i have used it already. Please help with that :)
#2 Posted : Friday, August 23, 2013 8:21:56 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
Please see the Automatic Audio Mixing option in the Input Settings
This is also explained in the help file
Similar Topics
Record Audio Inputs (Feature Requests)
by Gerard 7/10/2026 8:59:58 AM(UTC)
Select channels from multichannel audio input (General Discussion)
by aidancomi 2/27/2026 7:18:30 AM(UTC)
vMix SDI audio input choppy (General Discussion)
by rwd29 10/22/2025 7:35:23 AM(UTC)
MultiCorder – Record Audio Inputs & Choose Audio per Camera It (Feature Requests)
by Charles P 10/1/2025 7:22:33 PM(UTC)
DAW as audio input (General Discussion)
by KRTWrhyder 5/17/2025 4:01:36 AM(UTC)
vMix recognizes audio inputs, but is not outputting audio (NDI)
by RobbieC 4/5/2025 3:37:58 AM(UTC)
Audio input problems - USB B from A&H SQ5 (General Discussion)
by AKMIX 3/18/2025 10:38:17 AM(UTC)
External Video Output Audio as Selectable Audio input (Feature Requests)
by Brian D. 2/1/2025 6:26:55 AM(UTC)
NDI Camera Input Lagging Audio Input From Osee Stream Deck (General Discussion)
by Ron Carter 2/1/2025 1:39:24 AM(UTC)
How to selectively mute Audio Inputs when specific video inputs are played? (General Discussion)
by JohnDoe415 1/12/2025 10:54:44 AM(UTC)
Windows 11 Audio Input error (General Discussion)
by Dam2media Solutions Int'l 12/18/2024 6:47:01 PM(UTC)
Use audio input and output from different devices ANDROID/IOS (select output audio) (vMix Call)
by andrecaleffi 7/23/2024 4:48:29 AM(UTC)
Audio input from Behringer x32 drops (General Discussion)
by John Hopkins 6/26/2024 7:56:40 AM(UTC)
4 channel Audio input on single SDI input (Feature Requests)
by mark 5/14/2024 6:03:39 PM(UTC)
Audio input sorgente analogica. (General Discussion)
by ste2024 4/16/2024 1:12:11 AM(UTC)
Nvidia Broadcast has disappeared as an Audio Input option (Beta Discussion)
by stephencousins 11/23/2023 11:19:46 PM(UTC)
Audio Input not workin (General Discussion)
by MarvinMortflix 11/2/2023 6:12:47 AM(UTC)
Audio inputs in VMIX machine are fine, but no audio going out to TF5 Mixer (vMix Call)
by Jason Jimmerson 10/27/2023 5:58:29 AM(UTC)
Zoom support for Cameras / Calls / Audio Inputs NDI feeds (Beta Discussion)
by AElfTech 10/25/2023 3:12:50 PM(UTC)
Audio input disconnects during live show (General Discussion)
by nidarosvideo 10/11/2023 8:02:30 AM(UTC)
Audio input drops in vMix: Behringer Umc202hd (General Discussion)
by Gerrit Grobler 9/25/2023 6:07:35 AM(UTC)
Audio input drops when switching inputs (General Discussion)
by kirbyk48 9/25/2023 3:53:25 AM(UTC)
Audio Input Gives Static Intermittently (General Discussion)
by rbsdapateam 7/21/2023 1:19:46 PM(UTC)
Audio Input & Bus "FX" Sends & Returns (Feature Requests)
by haloflyer 3/21/2023 9:28:16 AM(UTC)
Advice on buying an external capture device with audio input and 1394 out port (Hardware Compatibility)
by Aahz 3/5/2023 8:32:03 PM(UTC)
Audio inputs not reconnecting (General Discussion)
by jmbmichael 2/7/2023 2:26:27 AM(UTC)
Camera Audio input Question (General Discussion)
by TechDad 7/21/2022 7:26:58 AM(UTC)
Audio Input Settings: Possibility to open ASIO Control Panel of driver (Feature Requests)
by engelschall 7/18/2022 3:58:38 AM(UTC)
Error adding more than four of the same audio input (General Discussion)
by bluesgeek 4/14/2022 9:36:31 PM(UTC)
Seperate NDI audio inputs in from MS TEAMS (NDI)
by MSFTGuruGuy 4/1/2022 5:58:08 AM(UTC)
