shd
#1 Posted : Tuesday, August 20, 2013 10:26:48 AM(UTC)
shd
I have question. After i play audio track and click CUT / QUICK PLAY for example on the images - audio track is turning off. Is it possible to add function in software, that audio track will not be disabled after using CUT / QUICK PLAY buttons if newer input dont have any audio embeeded? This would be great. I know that i can use overlays, but i have used it already. Please help with that :)
#2 Posted : Friday, August 23, 2013 8:21:56 AM(UTC)
Please see the Automatic Audio Mixing option in the Input Settings
This is also explained in the help file
Similar Topics
Record Audio Inputs (Feature Requests)
by Gerard 7/10/2026 8:59:58 AM(UTC)
Select channels from multichannel audio input (General Discussion)
by aidancomi 2/27/2026 7:18:30 AM(UTC)
vMix SDI audio input choppy (General Discussion)
by rwd29 10/22/2025 7:35:23 AM(UTC)
MultiCorder – Record Audio Inputs & Choose Audio per Camera It (Feature Requests)
by Charles P 10/1/2025 7:22:33 PM(UTC)
DAW as audio input (General Discussion)
by KRTWrhyder 5/17/2025 4:01:36 AM(UTC)
vMix recognizes audio inputs, but is not outputting audio (NDI)
by RobbieC 4/5/2025 3:37:58 AM(UTC)
Audio input problems - USB B from A&H SQ5 (General Discussion)
by AKMIX 3/18/2025 10:38:17 AM(UTC)
External Video Output Audio as Selectable Audio input (Feature Requests)
by Brian D. 2/1/2025 6:26:55 AM(UTC)
NDI Camera Input Lagging Audio Input From Osee Stream Deck (General Discussion)
by Ron Carter 2/1/2025 1:39:24 AM(UTC)
How to selectively mute Audio Inputs when specific video inputs are played? (General Discussion)
by JohnDoe415 1/12/2025 10:54:44 AM(UTC)
Windows 11 Audio Input error (General Discussion)
by Dam2media Solutions Int'l 12/18/2024 6:47:01 PM(UTC)
Use audio input and output from different devices ANDROID/IOS (select output audio) (vMix Call)
by andrecaleffi 7/23/2024 4:48:29 AM(UTC)
Audio input from Behringer x32 drops (General Discussion)
by John Hopkins 6/26/2024 7:56:40 AM(UTC)
4 channel Audio input on single SDI input (Feature Requests)
by mark 5/14/2024 6:03:39 PM(UTC)
Audio input sorgente analogica. (General Discussion)
by ste2024 4/16/2024 1:12:11 AM(UTC)
Nvidia Broadcast has disappeared as an Audio Input option (Beta Discussion)
by stephencousins 11/23/2023 11:19:46 PM(UTC)
Audio Input not workin (General Discussion)
by MarvinMortflix 11/2/2023 6:12:47 AM(UTC)
Audio inputs in VMIX machine are fine, but no audio going out to TF5 Mixer (vMix Call)
by Jason Jimmerson 10/27/2023 5:58:29 AM(UTC)
Zoom support for Cameras / Calls / Audio Inputs NDI feeds (Beta Discussion)
by AElfTech 10/25/2023 3:12:50 PM(UTC)
Audio input disconnects during live show (General Discussion)
by nidarosvideo 10/11/2023 8:02:30 AM(UTC)
Audio input drops in vMix: Behringer Umc202hd (General Discussion)
by Gerrit Grobler 9/25/2023 6:07:35 AM(UTC)
Audio input drops when switching inputs (General Discussion)
by kirbyk48 9/25/2023 3:53:25 AM(UTC)
Audio Input Gives Static Intermittently (General Discussion)
by rbsdapateam 7/21/2023 1:19:46 PM(UTC)
Audio Input & Bus "FX" Sends & Returns (Feature Requests)
by haloflyer 3/21/2023 9:28:16 AM(UTC)
Advice on buying an external capture device with audio input and 1394 out port (Hardware Compatibility)
by Aahz 3/5/2023 8:32:03 PM(UTC)
Audio inputs not reconnecting (General Discussion)
by jmbmichael 2/7/2023 2:26:27 AM(UTC)
Camera Audio input Question (General Discussion)
by TechDad 7/21/2022 7:26:58 AM(UTC)
Audio Input Settings: Possibility to open ASIO Control Panel of driver (Feature Requests)
by engelschall 7/18/2022 3:58:38 AM(UTC)
Error adding more than four of the same audio input (General Discussion)
by bluesgeek 4/14/2022 9:36:31 PM(UTC)
Seperate NDI audio inputs in from MS TEAMS (NDI)
by MSFTGuruGuy 4/1/2022 5:58:08 AM(UTC)
