Error adding more than four of the same audio input
I'm running vMix Pro 25.0.0.29 x64 in Windows 11. I have two 4-port HDMI Yuan cards (SC0710). I am not able to use the same audio capture for more than four inputs using any of the audio devices associated with the cards. (Error 0x88890008A). I sometimes get the error when adding a new audio input that is repeat of an existing one: No combination of intermediate filters could be found to make the connection. I have tried following the instructions here: https://www.vmix.com/kno...en-adding-an-audio-inputHowever, the format can't be changed from 48000 Hz to 41000 Hz. Is this a limit with the Yuan cards, or with vMix? Thank you!
