bluesgeek
#1 Posted : Thursday, April 14, 2022 9:36:31 PM(UTC)
bluesgeek
I'm running vMix Pro 25.0.0.29 x64 in Windows 11.
I have two 4-port HDMI Yuan cards (SC0710).
I am not able to use the same audio capture for more than four inputs using any of the audio devices associated with the cards. (Error 0x88890008A).
I sometimes get the error when adding a new audio input that is repeat of an existing one: No combination of intermediate filters could be found to make the connection.
I have tried following the instructions here: https://www.vmix.com/kno...en-adding-an-audio-input
However, the format can't be changed from 48000 Hz to 41000 Hz.
Is this a limit with the Yuan cards, or with vMix?
Thank you!
