dsharon
#1 Posted : Thursday, March 28, 2013 11:50:56 AM(UTC)
dsharon
I'm new to Vmix and it looks great.
The main problem I'm facing relates to performance and I kindly ask for your advise:
Upon opening 3 clips/players, the frame rate drops + the recordings has a lot of dropped frames.
While in project, the system indicates that the utilization is no greater than 25%, black magic disk speeed indicates 220MB/s write and 224MB/s read - so I assume it isn't due to lack of resources.
Here's the log output:
27/03/2013 14:52:44, Version:9.0.0.124
27/03/2013 14:52:44, Size: 1920x1080
27/03/2013 14:52:44, System: PAL 50i or 25p
27/03/2013 14:52:44, Codec: Decklink MJPEG Compressor
27/03/2013 14:52:44, RestartInterval: 0
27/03/2013 14:52:44, StartRecording
27/03/2013 17:03:27, StopRecording
27/03/2013 17:03:27, Duration: 02:10:43
27/03/2013 17:03:27, Frames: 140298
27/03/2013 17:03:27, DroppedFrames: 111561
27/03/2013 17:03:27, DueToSourceFrameRate: 55784
27/03/2013 17:03:27, DueToHardDiskOrCPU: 55777
Hardware:
Intel i7 2600K
Ram: 8GB
win 7 64bit
Gforce GTX 470
MB: Gigabyte GA-Z68A-D3H-BE
DeckLink HD Extreme 3
DeckLink Intensity Pro
Video RAID: 2 X 2TB, 7200rpm, raid0
Kind Regards,
Sharon.
#2 Posted : Thursday, March 28, 2013 12:38:10 PM(UTC)
What is the format and compression of the clips you are playing back?
dsharon
#3 Posted : Thursday, March 28, 2013 12:59:50 PM(UTC)
dsharon
Dear martin,
Thanks for your prompt replay.
I'm playing 3 files:
1. Microsoft "Wild Life" - the default clip with win7 - 1280 X 720, 5942kbps
2. wmv file, 320X180, datarate 443kbps
3. AVI file, 2048X1080, 16981kbps
Kind Regards,
Sharon
dsharon
#4 Posted : Thursday, March 28, 2013 1:15:47 PM(UTC)
dsharon
Dear Martin,
I appreciate if you can instruct me what are the bottle necks - thing I should avoid - i.e. mixing codecs and resolutions is it strictly "do not do" or may be ok with proper hardware?.
What would be your recommendation, hardware wise, in order to upgrade the system, in terms of performance - what is the component that has a vast impact on performance hence should be upgraded first and / or I should invest most?
Kind Regards,
Sharon.
#5 Posted : Thursday, March 28, 2013 2:13:24 PM(UTC)
vMix doesn't require a lot of resources, the specs you have listed are well and truly enough to handle the majority of situations, so this is a particularly strange problem.
Have you tried just playing each clip separately then adding a second clip until the problem appears?
dsharon
#6 Posted : Thursday, March 28, 2013 2:20:27 PM(UTC)
dsharon
Yes, I did try that.
On its own - each clip doesn't cause the system to drop frame or stutter. Upon adding few clips - the problem starts to appear (I can see that the clip is not played at 25fps in the clip window).
I noticed that Vmix is brilliant - among other things/features, in terms of using the hardware in an efficient way. Hence my question - what resource can I "through in" to help Vmix handle the clips better.
Sharon
macjaeger
#7 Posted : Thursday, March 28, 2013 2:27:31 PM(UTC)
macjaeger
What are the framerates of your clips, especially: are they all the same? And what is your system frame rate? Maybe there is a difference, like mixing 24fps and 30fps sources to a 50p output...
dsharon
#8 Posted : Thursday, March 28, 2013 3:01:24 PM(UTC)
dsharon
The MS clip is 30 fps.
All other are 25 fps.
I'll render all clips to one format, size, fps and give it a spin. Will post my result here.
regarding right to left lang. such as Hebrew - how can I make ticker to run from right to left?
Sharon
Similar Topics
Youtube Livestream stuttering, no dropped frames (General Discussion)
by DeanJohnsonProductions 4/24/2026 4:58:24 PM(UTC)
Feature Request: Expose Dropped Frames & Health Stats in API XML (Stream, Record, SRT) (Feature Requests)
by bulent_atlas 12/8/2025 4:46:20 PM(UTC)
Dropped frames in recording due to slow PC or Internet? (General Discussion)
by WILRI01 10/2/2024 4:15:35 AM(UTC)
BUG? Dropped frames counter max? (General Discussion)
by h2video.nl 5/13/2023 8:12:41 PM(UTC)
Massive Dropped Frames Via Screen Capture to Vmix (NDI)
by Dazzer89 10/3/2022 10:12:43 PM(UTC)
Dropped frames on input and external after VMix 25 update (General Discussion)
by Vince Beck 9/8/2022 3:37:49 PM(UTC)
Micro stutters/dropped frames (General Discussion)
Belarus bobdrad 5/2/2022 5:29:50 AM(UTC)
vMixCall to Output - dropped frames (vMix Call)
by StudiovMix1 3/11/2022 1:58:46 AM(UTC)
very high Rendere Dropped Frames (General Discussion)
by ezoN 1/6/2022 1:01:03 AM(UTC)
Has anyone got 1080p50 working with no dropped frames? (NDI)
by nomski 9/3/2021 6:06:13 PM(UTC)
Record Button Turns Yellow on Dropped Frames (Feature Requests)
by aircooled76@gmail.com 4/23/2021 10:26:56 AM(UTC)
Render time spikes and dropped frames (General Discussion)
by tomtailford 4/22/2021 3:38:52 AM(UTC)
NDI dropped frames in VMIX capture only (NDI)
by ejkravetz 4/16/2021 5:27:09 AM(UTC)
NDI Dropped Frames (General Discussion)
by gujingc 4/16/2021 4:29:42 AM(UTC)
Dropped Frames - But Only MPEG2 (General Discussion)
by kjones9999 2/24/2021 7:29:34 AM(UTC)
dropped frames with Quadro RTX 4000 GPU (General Discussion)
by enigmothy 10/11/2020 5:49:16 AM(UTC)
NDI dropped frames from 2nd PC (NDI)
by Gunnar Hauth 8/25/2020 8:43:02 AM(UTC)
Simple NDI Setup, massive dropped frames (NDI)
by reezyfasheezy 7/19/2020 12:46:27 PM(UTC)
Dropped Frames and Latency (General Discussion)
by davenv 6/29/2020 1:43:02 AM(UTC)
Need help with flicker (or dropped frames?) (General Discussion)
by Pops 6/26/2020 2:31:24 AM(UTC)
SRT Source Dropped Frames? (SRT)
by Plamen 6/25/2020 12:59:00 PM(UTC)
dropped Frames with Decklink Duo2 and vMix 23.0.0.57 (General Discussion)
by newmans 6/8/2020 4:54:27 AM(UTC)
Renderer Dropped Frames on External Output (General Discussion)
by MickG 3/17/2020 12:19:45 PM(UTC)
Dropped frames in Headset device without having such? (Hardware Compatibility)
by noonsong 9/10/2019 2:26:25 AM(UTC)
Thousands of dropped frames (multicorder, cam input only) (General Discussion)
by ebjorno 7/20/2018 4:20:41 AM(UTC)
Dropped frames due to source framerate?? (General Discussion)
by spencerm24 6/17/2018 2:02:25 AM(UTC)
Dropped Frames Over NDI From macbook (NDI)
by nowski 12/15/2017 11:39:21 AM(UTC)
Multicorder dropped frames (General Discussion)
by nowski 11/7/2017 9:47:52 AM(UTC)
Dropped Frames, DueToSourceFrameRate, MAJOR Audio/Video Sync Issues when Editing, Please help! (General Discussion)
by Ragnvald 3/20/2017 1:33:18 AM(UTC)
Are some dropped frames normal? (General Discussion)
by kjones9999 2/5/2017 10:43:07 PM(UTC)
