videologic
#1 Posted : Tuesday, April 20, 2010 5:12:26 PM(UTC)
videologic
Is there any possiblity to include a live Skype call into vMix ?
Rgds, Daan
#2 Posted : Wednesday, April 21, 2010 8:58:21 AM(UTC)
Not directly, however you can setup a separate computer with the Skype call and use the Desktop Capture feature to capture the screen over the network.
videologic
#3 Posted: : Wednesday, April 21, 2010 1:55:03 PM(UTC)
videologic
Hmm. but I understood that we only can use 5 f/s for caputure.. So not a real solution ?
Rgds, Daan
videologic
#4 Posted : Friday, April 30, 2010 5:55:22 PM(UTC)
videologic
Hope for an answer on this one ;-)
#5 Posted : Friday, April 30, 2010 10:31:13 PM(UTC)
Answer is as provided. No other support available as Skype do not offer any integration options.
#6 Posted : Friday, October 14, 2011 7:37:12 PM(UTC)
The Desktop Capture feature allows you to set which part of the screen is captured using the x,y, width and height options.
The frame rate can also be adjusted.
dove8369
#7 Posted : Thursday, April 18, 2013 6:41:43 PM(UTC)
dove8369
videologic wrote:
Rgds, Daan
Yes there is a great way to add Skype calls to a vmix live broadcast.
1)First u need to get Virtual Audio Cables.
2)Then set your computer audio output to line 1.
This can be found if you right click the speaker in the lower right hand corner open playback devices.
3) open Skype and set your microphone to microphone and speakers 2 headphone speakers output thats your computer's default output.
4) open vmix and in the lower left hand corner add input go to audio input and set it to stereo mix (IDT HD Audio CODEC)
Go to capture and open your webcam and click the i...go to the multi view and in overlay 1 set it to IDT HD Audio codec.
The webcam will pick up the audio from the speakers if you don't have internal computer speakers can get some external speakers it sounds great and you can hear your Skype calls. The only thing is you won't be able to hear your video playback unless you listen to it from: another computer or cell phone I have downloaded the free ustream app. For my ph.
To check my audio everything sounds great and you can ajust your audio settings. From vmix.
Similar Topics
skype / vMix dont appear in NDI (NDI)
by davidcl 11/7/2023 7:45:40 PM(UTC)
NDI and Skype Setup (NDI)
by Simsyuk 9/28/2023 9:39:40 PM(UTC)
NDI and Skype (SOLVED) (General Discussion)
by Simsyuk 4/30/2022 5:44:41 AM(UTC)
incoming calls from skype, google meet,etc (Feature Requests)
by LaloTowerz 6/18/2021 8:58:30 AM(UTC)
vMix External Camera Artifacting on Zoom and Skype (General Discussion)
by mingus 1/14/2021 6:50:57 AM(UTC)
Skype & Vmix Call (General Discussion)
by NMG4 11/18/2020 4:33:15 AM(UTC)
SKYPE MULTIPLE CALLER INPUT AUDIO QUESTION (General Discussion)
by J.LAVARIAS 10/2/2020 9:31:50 PM(UTC)
Skype via NDI vs Vmixcall (vMix Call)
by NTSC 9/24/2020 9:13:25 AM(UTC)
Different output to Skype (General Discussion)
by Simsyuk 8/28/2020 9:50:51 PM(UTC)
Skype NDI from second PC (General Discussion)
by kgoodyer 8/20/2020 7:54:45 AM(UTC)
Skype Inputs (General Discussion)
by Simsyuk 6/3/2020 9:37:36 PM(UTC)
Skype Audio Peculiarity (General Discussion)
by Maximus 5/29/2020 10:10:08 PM(UTC)
pre-populate Skype inputs (Feature Requests)
by srbh41413 5/24/2020 9:24:46 PM(UTC)
SKYPE 8.6 & NDI (NDI)
by fcarva22 5/22/2020 5:37:39 AM(UTC)
vMix + NDI + Skype Issue (NDI)
by davenv 5/21/2020 8:09:36 PM(UTC)
SKype NDI Multicorder Issues (NDI)
by wowgreatoctopus 5/12/2020 11:33:30 PM(UTC)
vMix - NDI - Skype with Remote Desktop (General Discussion)
by jb1206 5/2/2020 1:52:13 AM(UTC)
Vmix output not showing up in skype for business (General Discussion)
by martin.zappe 4/9/2020 6:01:34 PM(UTC)
skype line(newtek NDi Audio) (NDI)
by Ketan Patel 4/6/2020 9:17:38 PM(UTC)
Skype e vmixcall (General Discussion)
by alucch 4/1/2020 11:56:42 PM(UTC)
Skype audio issue (General Discussion)
by yorg 3/30/2020 6:48:41 PM(UTC)
Capture skype sound (General Discussion)
by Aahz 3/15/2020 8:28:04 AM(UTC)
Skype with NDI: caller audio signal chopped (NDI)
by Whisper 2/5/2020 1:30:45 AM(UTC)
Virtual Audio Cables with vMix, Zoom, and Skype (General Discussion)
by mgrayeb 2/3/2020 5:28:06 PM(UTC)
Is not displayed in VMIX the images from skype applicaction (NDI)
by lpesiney 1/31/2020 8:57:22 AM(UTC)
Skype NDI (NDI)
by mkrigsman 12/23/2019 11:37:15 AM(UTC)
Can't see NDI Camera in Skype (NDI)
by stevemullins 10/12/2019 7:30:01 AM(UTC)
Skype still having issues (General Discussion)
by Simsyuk 10/10/2019 1:55:57 AM(UTC)
Skype & vMix don't like one another (General Discussion)
by Simsyuk 10/2/2019 5:53:25 PM(UTC)
Screen Flashes Black when using Skype (General Discussion)
by Simsyuk 9/3/2019 6:58:11 AM(UTC)
