wtmuradiotv
#1 Posted : Monday, April 10, 2017 3:09:28 PM(UTC)
wtmuradiotv
Not running pro cameras but here's the issue i am having .Back ago i added a few cameras in the mix at one time they were working fine with vmix now the program will not acknowledge them states something about pins not set right .Why is vmix not seeing them i have the slightest clue .Maybe someone can highlight me on this issue .All though they work for skype etc
#2 Posted : Monday, April 10, 2017 3:39:11 PM(UTC)
@ wtmuradiotv
You might need to supply a little more information about your issue, like how are you connecting your cameras to your computer?
wtmuradiotv
#3 Posted : Tuesday, April 11, 2017 7:58:27 PM(UTC)
wtmuradiotv
IceStream wrote:
@ wtmuradiotv
Usb as normal ....These have always been in line and were at one time working on vmix now since all the updates seems only one likes vmix the others seem to have connection issues even when i put the right info in
#4 Posted : Tuesday, April 11, 2017 9:02:06 PM(UTC)
As of v19, Webcams will now default to MJPG. Maybe yours prefer UVC as before?
You can try this while adding your inputs.
Similar Topics
PTZOptics Cameras Freeze over NDI (NDI)
by fcd 7/23/2025 4:07:59 AM(UTC)
Support 10 Replay Cameras & Flexible Storage (Feature Requests)
by gugacdb 5/30/2025 4:14:03 AM(UTC)
Timecode to Multicorder, Recorder and Cameras Hack (General Discussion)
by nowski 3/30/2025 12:15:01 AM(UTC)
Referece system for 20 NDI PTZ Cameras 2K @ 60 FPS (Systems)
by Bulldog 2/20/2025 9:33:26 AM(UTC)
Help Needed with SMTAV IP PTZ Cameras Positioning Issue (Hardware Compatibility)
by jacan sevada 1/13/2025 12:14:50 PM(UTC)
cameras are not showing in Vmix (General Discussion)
by daclifton 11/18/2024 12:58:52 AM(UTC)
How to record 6 cameras in sync and individually for post editing (General Discussion)
by John Hopkins 11/5/2024 8:26:19 AM(UTC)
NDI Cameras with black input (General Discussion)
by bscarbrough1903 9/2/2024 4:28:50 AM(UTC)
NDI Cameras are showing up as just black on inputs (NDI)
by ab800 8/21/2024 6:32:37 AM(UTC)
Cameras 2-4 ghosted (Instant Replay)
by vjmandala 5/14/2024 2:56:32 PM(UTC)
Troubleshooting CPU overload in Vmix with 3 cameras and Blackmagic capture card (General Discussion)
by GameWithSasha 3/27/2024 8:03:39 AM(UTC)
4 Cameras in USB Hub (Hardware Compatibility)
by elfabe028 2/14/2024 1:20:53 PM(UTC)
Zoom support for Cameras / Calls / Audio Inputs NDI feeds (Beta Discussion)
by AElfTech 10/25/2023 3:12:50 PM(UTC)
Best Cameras for Long Event Streams (General Discussion)
by zachEEP 4/9/2023 4:03:46 AM(UTC)
Cameras Stopped Showing Up (General Discussion)
by spydervenom 3/9/2023 10:48:57 AM(UTC)
vMix and PTZ Cameras info request (General Discussion)
by LuMags 3/6/2023 3:05:09 AM(UTC)
PTZ Optics Cameras & Focus Presets (Hardware Compatibility)
by hparsons 1/25/2023 2:30:28 AM(UTC)
Virtual PTZ movement check - don't move cameras in program by mistake (Feature Requests)
by jeregan 1/20/2023 7:32:02 PM(UTC)
Cameras lagg/drop frames. (General Discussion)
by t_dash 12/1/2022 2:44:09 AM(UTC)
vMix 8 cameras replay on Intel 12900 (Systems)
by tkachuk.alex 8/2/2022 9:13:45 PM(UTC)
Cameras Not Showing Up (Hardware Compatibility)
by CCBC2190 7/29/2022 12:26:56 PM(UTC)
Assistance Needed with Adding PTZ Camera Controller and Three Cameras to vMix (NDI)
by tluttrell 7/11/2022 5:40:27 AM(UTC)
How do I delete the virtual cameras generated by VMIX (General Discussion)
by mengxun 7/7/2022 9:18:03 PM(UTC)
AvMatrix Ts3019 Tally ligths for LDK cameras CCU (Hardware Compatibility)
by Gaizka 5/25/2022 8:54:32 PM(UTC)
How do I chroma key two different cameras in ATEM MINI? (General Discussion)
by curiousgeorge 4/10/2022 4:42:33 PM(UTC)
Shortcut or API call for button "Swap Cameras between Replay A and Replay B (Feature Requests)
by kevev 1/28/2022 10:46:44 AM(UTC)
auto select all cameras for replay (Feature Requests)
by gary_co 11/11/2021 6:45:58 PM(UTC)
Input IP cameras into vMix (General Discussion)
by Simsyuk 10/5/2021 9:19:54 PM(UTC)
I'm trying to switch cameras as overlay via midi, on a desktop capture. How? (General Discussion)
by Trujillo 7/11/2021 9:13:38 AM(UTC)
Need to reconnect cameras each time (General Discussion)
by EGSiegel 5/25/2021 6:00:00 AM(UTC)
