Fconcepoion
#1 Posted : Wednesday, May 1, 2013 4:37:22 PM(UTC)
Fconcepoion
How can I ad more virtual set to the system?
macjaeger
#2 Posted : Thursday, May 2, 2013 5:59:53 AM(UTC)
macjaeger
Virtual sets are a combination of graphics and a configuration file called "config.xml". Take a look into the exemplary virtualsets inside "programms\vMix\VirtualSets\...", especially open the config.xml in a text-editor and examine it, it's pretty much self explanatory.
Fconcepoion
#3 Posted : Thursday, May 2, 2013 5:29:02 PM(UTC)
Fconcepoion
Thanks.
Fconcepoion
#4 Posted : Friday, May 3, 2013 2:37:47 PM(UTC)
Fconcepoion
I'm sorry, but look like I'm not so good working with this, script
could you show me how I can I change the background set...
<?xml version="1.0"?>
-<virtualSet><input dynamic="true" zoom="0.224" y="0.149" x="0.001" name="Screen">a.png</input><input zoom="1" y="0" x="0" name="Set">background.png</input><input dynamic="true" zoom="0.1765" y="-0.255" x="0.005" name="Talent">talent.png</input><input zoom="0.4096875" y="-0.8022223" x="0.005" name="Table">foreground.crop.png</input><zoom zoom="3.818" y="0.942" x="-0.009" name="Close Up"/><zoom zoom="2.313" y="0.081" x="-0.027" name="Medium Shot"/><zoom zoom="1" y="0" x="0" name="Full"/><zoom zoom="1" y="0" x="0" name="Custom"/></virtualSet>
Damn2Good4U
#5 Posted : Friday, May 3, 2013 6:20:19 PM(UTC)
Damn2Good4U
What do you wanna do? Add me on Skype and we can work it out together... Hence send me your graphics for d virtual set and I will try to help u put them together....
macjaeger
#6 Posted : Saturday, May 4, 2013 8:08:21 AM(UTC)
macjaeger
The background of this set is the file background.png. Put your own background image in the same folder, and name it anything you like, e.g. "my_background.png". Then change the filename in the xml-file, like this:
<input zoom="1" y="0" x="0" name="Set">my_background.png</input>
No magic there.
Damn2Good4U
#7 Posted : Saturday, May 4, 2013 8:33:10 AM(UTC)
Damn2Good4U
No magic there.
Hello
@Macjaeger just said it all, there is no magic at all... just do as above and u will be fine...
TeODH4
#8 Posted : Tuesday, May 14, 2013 1:46:45 PM(UTC)
TeODH4
I have to say the main thing I love about vMix is how easily you can add your own titles, virtual sets, etc. With a very low learning curve at that. At least if you have some form of code development under your belt. Heck, all you really need to understand is HTML or XML and just start paying with settings until you get it right. :-)
Even myself never having worked with xaml before, I was able to make a custom lower third in a matter of about 10 mins.
Guest (6)
Similar Topics
Chroma Key access through API (Feature Requests)
by michaelthomasbrennan 4/3/2026 12:45:52 AM(UTC)
chroma key - can't remove orange (General Discussion)
by xxsuna 11/25/2022 6:51:23 PM(UTC)
CHROMA KEY IN ATEM OR VMIX? (General Discussion)
by curiousgeorge 4/15/2022 3:12:17 PM(UTC)
How do I chroma key two different cameras in ATEM MINI? (General Discussion)
by curiousgeorge 4/10/2022 4:42:33 PM(UTC)
CHROMA KEY IN ATEM MINI PRO ISO OR VMIX? (General Discussion)
by curiousgeorge 4/10/2022 10:50:27 AM(UTC)
Chroma Key on Video file (General Discussion)
by Victoryindy 6/2/2021 3:21:43 AM(UTC)
Chroma key functions in shortcuts and API (Feature Requests)
by Mathijs 5/22/2021 2:16:56 AM(UTC)
Chroma Key: green contours while using a blue screen (General Discussion)
by JoostH 4/22/2021 6:40:00 PM(UTC)
Chroma Key distortion issue? (General Discussion)
by Karsten 11/13/2020 12:23:12 PM(UTC)
Chroma Key stays Green (General Discussion)
by mikel2051 9/17/2020 4:33:19 AM(UTC)
chroma key question (General Discussion)
by danlwil 8/29/2020 7:20:48 AM(UTC)
Chroma Key on vMix Call (vMix Call)
by ribbrat 7/10/2020 10:00:57 PM(UTC)
COME USARE CHROMA KEY E VIRTUAL SET (General Discussion)
by Diegone 9/9/2019 6:05:05 PM(UTC)
Version 22.0.0.51 the chroma key has stopped working (General Discussion)
by rpavanello 3/14/2019 12:40:28 AM(UTC)
Chroma Key suddenly going berserk (General Discussion)
by tlovegrove 5/9/2018 8:12:40 PM(UTC)
Improved Chroma Keying in VMix 22 (Feature Requests)
by waynew 5/1/2018 11:06:26 AM(UTC)
vMix Help - Chroma Key section needs updating (General Discussion)
by sinc747 2/14/2018 11:33:18 AM(UTC)
Invert Chroma Key Mask (General Discussion)
by bobdoyle 12/19/2017 5:20:35 PM(UTC)
Chroma key failure (Hardware Compatibility)
by Berts 10/6/2017 6:43:38 PM(UTC)
Chroma Key (General Discussion)
by ccolewilliam 9/17/2017 9:50:24 AM(UTC)
Chroma Key Bright (General Discussion)
by ccolewilliam 8/24/2017 2:47:10 PM(UTC)
Problem chroma key filter (General Discussion)
by NeObr 3/17/2017 10:57:15 AM(UTC)
ProPresenter 6 to vMix via NDI and chroma key issues (NDI)
by Nick Davidson 2/15/2017 10:51:21 AM(UTC)
chroma key virtual set (General Discussion)
by op music 11/15/2016 6:46:13 AM(UTC)
Razer Chroma Keyboard lights... (Feature Requests)
by ne02005 10/21/2016 1:03:20 PM(UTC)
Chroma key no longer functioning properly after latest update? (General Discussion)
by djevo1 10/17/2016 9:48:36 AM(UTC)
How to crop a Chroma Keyed Camera Shot with an Image Background in a side-by-side Multiview? (General Discussion)
by sinc747 8/31/2016 6:47:17 PM(UTC)
Issue with RGB sliders in Chroma key settings (General Discussion)
by richardgatarski 4/27/2016 4:33:28 AM(UTC)
by ccolewilliam 2/7/2016 2:12:09 AM(UTC)
by ccolewilliam 10/5/2015 8:11:54 PM(UTC)
