wtmuradiotv
#1 Posted : Monday, May 8, 2017 3:10:28 PM(UTC)
wtmuradiotv
AddNewInput.INPUT_CAPTURE
This pin cannot use the supplied media type.
Anyone know why this is happening with the cameras i got all but one to work now ????? They worked before
#2 Posted : Monday, May 8, 2017 3:28:40 PM(UTC)
Hi
which camera type is it? A webcam ?
wtmuradiotv
#3 Posted : Monday, May 8, 2017 3:40:58 PM(UTC)
wtmuradiotv
Yes all but a hp i have running other then that the other ones i had running come up with that error message when i add them all though the vmix is picking them up they are in the list
#4 Posted : Monday, May 8, 2017 3:48:45 PM(UTC)
I think it needs a special video format, not the default one which is now MJPEG. Try other options.
wtmuradiotv
#5 Posted : Monday, May 8, 2017 4:21:00 PM(UTC)
wtmuradiotv
I have seems it still comes up with issues ...Im not about to switch all these cameras thats nuts when they all worked before all these updates on vmix
Similar Topics
Help with adding RTSP cameras inputs through API Calls (General Discussion)
by MartinC79 3/24/2026 2:51:41 AM(UTC)
PTZOptics Cameras Freeze over NDI (NDI)
by fcd 7/23/2025 4:07:59 AM(UTC)
Support 10 Replay Cameras & Flexible Storage (Feature Requests)
by gugacdb 5/30/2025 4:14:03 AM(UTC)
Timecode to Multicorder, Recorder and Cameras Hack (General Discussion)
by nowski 3/30/2025 12:15:01 AM(UTC)
Referece system for 20 NDI PTZ Cameras 2K @ 60 FPS (Systems)
by Bulldog 2/20/2025 9:33:26 AM(UTC)
Help Needed with SMTAV IP PTZ Cameras Positioning Issue (Hardware Compatibility)
by jacan sevada 1/13/2025 12:14:50 PM(UTC)
cameras are not showing in Vmix (General Discussion)
by daclifton 11/18/2024 12:58:52 AM(UTC)
How to record 6 cameras in sync and individually for post editing (General Discussion)
by John Hopkins 11/5/2024 8:26:19 AM(UTC)
NDI Cameras with black input (General Discussion)
by bscarbrough1903 9/2/2024 4:28:50 AM(UTC)
NDI Cameras are showing up as just black on inputs (NDI)
by ab800 8/21/2024 6:32:37 AM(UTC)
Cameras 2-4 ghosted (Instant Replay)
by vjmandala 5/14/2024 2:56:32 PM(UTC)
Troubleshooting CPU overload in Vmix with 3 cameras and Blackmagic capture card (General Discussion)
Belarus GameWithSasha 3/27/2024 8:03:39 AM(UTC)
4 Cameras in USB Hub (Hardware Compatibility)
by elfabe028 2/14/2024 1:20:53 PM(UTC)
Zoom support for Cameras / Calls / Audio Inputs NDI feeds (Beta Discussion)
by AElfTech 10/25/2023 3:12:50 PM(UTC)
Best Cameras for Long Event Streams (General Discussion)
by zachEEP 4/9/2023 4:03:46 AM(UTC)
Cameras Stopped Showing Up (General Discussion)
by spydervenom 3/9/2023 10:48:57 AM(UTC)
vMix and PTZ Cameras info request (General Discussion)
by LuMags 3/6/2023 3:05:09 AM(UTC)
PTZ Optics Cameras & Focus Presets (Hardware Compatibility)
by hparsons 1/25/2023 2:30:28 AM(UTC)
Virtual PTZ movement check - don't move cameras in program by mistake (Feature Requests)
by jeregan 1/20/2023 7:32:02 PM(UTC)
Cameras lagg/drop frames. (General Discussion)
by t_dash 12/1/2022 2:44:09 AM(UTC)
vMix 8 cameras replay on Intel 12900 (Systems)
by tkachuk.alex 8/2/2022 9:13:45 PM(UTC)
Cameras Not Showing Up (Hardware Compatibility)
by CCBC2190 7/29/2022 12:26:56 PM(UTC)
Assistance Needed with Adding PTZ Camera Controller and Three Cameras to vMix (NDI)
by tluttrell 7/11/2022 5:40:27 AM(UTC)
How do I delete the virtual cameras generated by VMIX (General Discussion)
by mengxun 7/7/2022 9:18:03 PM(UTC)
AvMatrix Ts3019 Tally ligths for LDK cameras CCU (Hardware Compatibility)
by Gaizka 5/25/2022 8:54:32 PM(UTC)
How do I chroma key two different cameras in ATEM MINI? (General Discussion)
by curiousgeorge 4/10/2022 4:42:33 PM(UTC)
Shortcut or API call for button "Swap Cameras between Replay A and Replay B (Feature Requests)
by kevev 1/28/2022 10:46:44 AM(UTC)
auto select all cameras for replay (Feature Requests)
by gary_co 11/11/2021 6:45:58 PM(UTC)
Input IP cameras into vMix (General Discussion)
by Simsyuk 10/5/2021 9:19:54 PM(UTC)
I'm trying to switch cameras as overlay via midi, on a desktop capture. How? (General Discussion)
by Trujillo 7/11/2021 9:13:38 AM(UTC)
