guztavo
#1 Posted : Sunday, December 9, 2012 11:33:14 PM(UTC)
guztavo
Hi Martin!
I'm writing because yesterday i've used vMix with some issues on the recording.
For a reason, vMix dropped about 300 frames on each recording of about 20 minutes. I can't find the exact moment because i'm with my head on the delay module and titles, and i see the dropped counter in some spontaeous times.
In the detail i can see that the problem is in the origin. I want to ask you if there is a way to know if the problem is the capture card, or is the camera?
I use Adobe Premiere downloading dv tapes without problems of dropped frames.
Thanks in advance.
Regards
#2 Posted : Sunday, December 9, 2012 11:38:33 PM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
There are two main causes for dropped source frames, graphics card or capture card.
Could you provide your complete system specs including graphics card and capture card.
Thanks,
guztavo
#3 Posted : Tuesday, December 11, 2012 7:55:53 PM(UTC)
guztavo
Hi Martin!
Thanks for your answer!
Yesterday i used vMix again, and checking, i saw that the dropped frames increases when i start playing a stored video delay at 50% (at least, i use that value). When i check the PGM record, i dont see (and hear) any problem.
So, it's logical that when you uses slow motion, you will have repeated frames, but i think they shouldn't plus in the dropped frames counter. Just a suggestion (and should be a big red light that shows when recording drop frames).
Core i7-2600K LGA1155 3.4GHZ
RADEON HD 6850 775M 1GB DDR5 HDMI DVI VGA
Motherboard ASUS P8H67 B3
RAM 2 x Kingston 4GB 1333 DIMM
Power: KC-CFA 780w
Capture card:
ENCORE ENL1394-PCI (3 DV inputs)
And vMix SD.
Thanks!!!
Regards.
watchfulone
#4 Posted : Tuesday, December 11, 2012 10:06:36 PM(UTC)
watchfulone
Was thanked: 17 time(s) in 14 post(s)
guztavo wrote:
Hi Martin!
Power: KC-CFA 780w
Capture card:
And vMix SD.
Thanks!!!
Regards.
Not the best capture cards to use, i once used that card (ENCORE ENL) and had to change it, i would however recommend using (DarkCrystal HD Capture Pro form AVerMedia)http://www.avermedia.com/product/ProductDetail.aspx?Id=528
And this is if you don't have a Black Magic Design Card. works well
#5 Posted : Tuesday, December 11, 2012 11:05:52 PM(UTC)
Guztavo,
Your system specs all look ok and would work fine in HD if you chose to upgrade in the future.
The dropped frames you are seeing is the result of the frame rate of a slow motion video delay.
This indicates vMix is correctly duplicating each frame to make up for the difference, this will still show up as dropped frames but the
final recording should still play back as per normal.
Similar Topics
Youtube Livestream stuttering, no dropped frames (General Discussion)
by DeanJohnsonProductions 4/24/2026 4:58:24 PM(UTC)
Feature Request: Expose Dropped Frames & Health Stats in API XML (Stream, Record, SRT) (Feature Requests)
by bulent_atlas 12/8/2025 4:46:20 PM(UTC)
Dropped frames in recording due to slow PC or Internet? (General Discussion)
by WILRI01 10/2/2024 4:15:35 AM(UTC)
BUG? Dropped frames counter max? (General Discussion)
by h2video.nl 5/13/2023 8:12:41 PM(UTC)
Massive Dropped Frames Via Screen Capture to Vmix (NDI)
by Dazzer89 10/3/2022 10:12:43 PM(UTC)
Dropped frames on input and external after VMix 25 update (General Discussion)
by Vince Beck 9/8/2022 3:37:49 PM(UTC)
Micro stutters/dropped frames (General Discussion)
by bobdrad 5/2/2022 5:29:50 AM(UTC)
vMixCall to Output - dropped frames (vMix Call)
by StudiovMix1 3/11/2022 1:58:46 AM(UTC)
very high Rendere Dropped Frames (General Discussion)
by ezoN 1/6/2022 1:01:03 AM(UTC)
Has anyone got 1080p50 working with no dropped frames? (NDI)
by nomski 9/3/2021 6:06:13 PM(UTC)
Record Button Turns Yellow on Dropped Frames (Feature Requests)
by aircooled76@gmail.com 4/23/2021 10:26:56 AM(UTC)
Render time spikes and dropped frames (General Discussion)
by tomtailford 4/22/2021 3:38:52 AM(UTC)
NDI dropped frames in VMIX capture only (NDI)
by ejkravetz 4/16/2021 5:27:09 AM(UTC)
NDI Dropped Frames (General Discussion)
by gujingc 4/16/2021 4:29:42 AM(UTC)
Dropped Frames - But Only MPEG2 (General Discussion)
by kjones9999 2/24/2021 7:29:34 AM(UTC)
dropped frames with Quadro RTX 4000 GPU (General Discussion)
by enigmothy 10/11/2020 5:49:16 AM(UTC)
NDI dropped frames from 2nd PC (NDI)
by Gunnar Hauth 8/25/2020 8:43:02 AM(UTC)
Simple NDI Setup, massive dropped frames (NDI)
by reezyfasheezy 7/19/2020 12:46:27 PM(UTC)
Dropped Frames and Latency (General Discussion)
by davenv 6/29/2020 1:43:02 AM(UTC)
Need help with flicker (or dropped frames?) (General Discussion)
by Pops 6/26/2020 2:31:24 AM(UTC)
SRT Source Dropped Frames? (SRT)
by Plamen 6/25/2020 12:59:00 PM(UTC)
dropped Frames with Decklink Duo2 and vMix 23.0.0.57 (General Discussion)
by newmans 6/8/2020 4:54:27 AM(UTC)
Renderer Dropped Frames on External Output (General Discussion)
by MickG 3/17/2020 12:19:45 PM(UTC)
Dropped frames in Headset device without having such? (Hardware Compatibility)
by noonsong 9/10/2019 2:26:25 AM(UTC)
Thousands of dropped frames (multicorder, cam input only) (General Discussion)
by ebjorno 7/20/2018 4:20:41 AM(UTC)
Dropped frames due to source framerate?? (General Discussion)
by spencerm24 6/17/2018 2:02:25 AM(UTC)
Dropped Frames Over NDI From macbook (NDI)
by nowski 12/15/2017 11:39:21 AM(UTC)
Multicorder dropped frames (General Discussion)
by nowski 11/7/2017 9:47:52 AM(UTC)
Dropped Frames, DueToSourceFrameRate, MAJOR Audio/Video Sync Issues when Editing, Please help! (General Discussion)
by Ragnvald 3/20/2017 1:33:18 AM(UTC)
Are some dropped frames normal? (General Discussion)
by kjones9999 2/5/2017 10:43:07 PM(UTC)
