ccolewilliam
#1 Posted : Sunday, February 7, 2016 2:12:09 AM(UTC)
ccolewilliam
Hey guys, quick question. I have been a long time vMix user. Love the program. I never have any problems. BUT, the only issue I have been having is with the Chroma Key. I use the software for weather and on the key there is always a slight pixelation around the person on the screen. I posted once on here a couple months ago with no real replay. Is there any possible adjustment or setting that can correct that? Its not horrible but it is quite noticeable.
GeorgeR
#2 Posted : Sunday, February 7, 2016 3:31:13 AM(UTC)
GeorgeR
Was thanked: 30 time(s) in 28 post(s)
ccolewilliam,
Usually the pixelation is caused by improper lighting and shadow areas on the Green Screen. Pixelation is also caused by the subject being too close to the backdrop. This YouTube video may help explain. I've started the video playback at 05:50 into the video
?t=5m50s.
Cheers!
~George
#3 Posted : Sunday, February 7, 2016 10:03:17 AM(UTC)
@ ccolewilliam
I can only assume you have already 'played' with the "Colour Key" settings (cog wheel/Colour Key) and set the "AntiAliasing" to Medium or High. It will soften your talent somewhat, but those are the only "Settings" within vMix to soften the edges of your key. Following good "Green Screen" practices as George suggests and using higher end cameras will also help to give a good clean key.
ccolewilliam
#4 Posted : Sunday, February 14, 2016 7:49:44 PM(UTC)
ccolewilliam
Hi Icestream... I do have anti alasing check marked on. How do I adjust it? That actually I think is my problem I just need the eged softened. The light is good and its not a shadow issue. It is just the edges. I just don't see a setting other than on or off for the anti alasing.
#5 Posted : Monday, February 15, 2016 2:28:25 AM(UTC)
@ ccolewilliam
You are probably best to play with all the settings in that window to figure out how it all works, it's not exactly straight forward...
However, I do find that the 'Auto Chroma Key' button usually works pretty good on it's own without having to adjust any of the settings (you may want to push 'Reset' first to clear any adjustments you've already tried).
The "AntiAliasing" option only has three settings: Low, Medium and High, but there should be a noticeable difference each from the other, 'High' being the softest.
ccolewilliam
#6 Posted : Monday, February 15, 2016 5:20:30 PM(UTC)
ccolewilliam
Ice, Thanks again for the info the only thing I can't figure out is where are the anti-alasing settings. I only see a check mark for on or off. I dont see a high or medium setting. Could you or someone else tell me where that is.
-William
#7 Posted : Monday, February 15, 2016 8:07:13 PM(UTC)
@ ccolewilliam
What Edition of vMix are you using?
In vMix 16 it's right next to the "Anti Aliasing" check box:
Similar Topics
chroma key - can't remove orange (General Discussion)
by xxsuna 11/25/2022 6:51:23 PM(UTC)
CHROMA KEY IN ATEM OR VMIX? (General Discussion)
by curiousgeorge 4/15/2022 3:12:17 PM(UTC)
How do I chroma key two different cameras in ATEM MINI? (General Discussion)
by curiousgeorge 4/10/2022 4:42:33 PM(UTC)
CHROMA KEY IN ATEM MINI PRO ISO OR VMIX? (General Discussion)
by curiousgeorge 4/10/2022 10:50:27 AM(UTC)
Chroma Key on Video file (General Discussion)
by Victoryindy 6/2/2021 3:21:43 AM(UTC)
Chroma key functions in shortcuts and API (Feature Requests)
by Mathijs 5/22/2021 2:16:56 AM(UTC)
Chroma Key: green contours while using a blue screen (General Discussion)
by JoostH 4/22/2021 6:40:00 PM(UTC)
Chroma Key distortion issue? (General Discussion)
by Karsten 11/13/2020 12:23:12 PM(UTC)
Chroma Key stays Green (General Discussion)
by mikel2051 9/17/2020 4:33:19 AM(UTC)
chroma key question (General Discussion)
by danlwil 8/29/2020 7:20:48 AM(UTC)
Chroma Key on vMix Call (vMix Call)
by ribbrat 7/10/2020 10:00:57 PM(UTC)
COME USARE CHROMA KEY E VIRTUAL SET (General Discussion)
by Diegone 9/9/2019 6:05:05 PM(UTC)
Version 22.0.0.51 the chroma key has stopped working (General Discussion)
by rpavanello 3/14/2019 12:40:28 AM(UTC)
Chroma Key suddenly going berserk (General Discussion)
by tlovegrove 5/9/2018 8:12:40 PM(UTC)
Improved Chroma Keying in VMix 22 (Feature Requests)
by waynew 5/1/2018 11:06:26 AM(UTC)
vMix Help - Chroma Key section needs updating (General Discussion)
by sinc747 2/14/2018 11:33:18 AM(UTC)
Invert Chroma Key Mask (General Discussion)
by bobdoyle 12/19/2017 5:20:35 PM(UTC)
Chroma key failure (Hardware Compatibility)
by Berts 10/6/2017 6:43:38 PM(UTC)
Chroma Key (General Discussion)
by ccolewilliam 9/17/2017 9:50:24 AM(UTC)
Chroma Key Bright (General Discussion)
by ccolewilliam 8/24/2017 2:47:10 PM(UTC)
Problem chroma key filter (General Discussion)
by NeObr 3/17/2017 10:57:15 AM(UTC)
ProPresenter 6 to vMix via NDI and chroma key issues (NDI)
by Nick Davidson 2/15/2017 10:51:21 AM(UTC)
chroma key virtual set (General Discussion)
by op music 11/15/2016 6:46:13 AM(UTC)
Razer Chroma Keyboard lights... (Feature Requests)
by ne02005 10/21/2016 1:03:20 PM(UTC)
Chroma key no longer functioning properly after latest update? (General Discussion)
by djevo1 10/17/2016 9:48:36 AM(UTC)
How to crop a Chroma Keyed Camera Shot with an Image Background in a side-by-side Multiview? (General Discussion)
by sinc747 8/31/2016 6:47:17 PM(UTC)
Issue with RGB sliders in Chroma key settings (General Discussion)
by richardgatarski 4/27/2016 4:33:28 AM(UTC)
by ccolewilliam 10/5/2015 8:11:54 PM(UTC)
How to record with chroma key (General Discussion)
by Faamt 6/25/2015 6:34:52 AM(UTC)
Creative Chroma key and Studio case (Showcase)
by richardgatarski 2/19/2015 7:05:51 AM(UTC)
