xrook1
#1 Posted : Saturday, April 4, 2015 9:02:30 PM(UTC)
xrook1
I recently downloaded demo version of vMix and love it so far. My camera is a Sony HDV-FX7 connected via firewire. Output settings from camera is 1440x1080i. Input settings for vMix match. Why am I experiencing "rendered dropped frames" and seeing interlaced lines?
Bardos
#2 Posted : Wednesday, April 8, 2015 7:47:41 PM(UTC)
Bardos
Groups: Guests
I was experiencing some very bad dropped frames for a while, with no answers from the forum...I did some experimenting today, and am please with the results I have....
I am using SD,NTSC, 720x480, so I set everything to 59.94i, turned on "Blend" for camera and video playback, ticked Interlaced recording, but am unable to keep the settings for my USB grabber to 59.94i, so I have it set to 29.97, and for 1 hour of recording, I have 3 dropped frames on internal HD, and 3 for the same period on a USB external HD, until I opened 'My Computer', then I got 16 dropped frames.....so, I will run another test, giving vMix the highest priority available to see what happens....
Update: I have also discovered that setting a high buffer for recording also adds to dropped frames....a buffer of 10 - 15 works ok, anything higher caused dropped frames with me...setting vMix to a high priority, causes PC problems, seems to be causing high rate of dropped frames........strange, but true......
richardgatarski
#3 Posted : Thursday, April 9, 2015 4:03:05 PM(UTC)
richardgatarski
@xrook1 You probably see interlaced lines because your Input settings does not match the camera's output. In particular the deinterlace option is not set. I think vMix should take care of this automatically. But in my experience sometimes a little bit of experimenation with settings in the camera, vMix Master frame rate, and the Input for the camera is required.
@both I think, judging from similar experiences I have had, that vMix takes care of difference in source (what the camera outputs) and Input/Master frame rate settings by "dropping frames". Frames might also be dropped if there is a problem with the camera signal (eg caused by a long cable).
On a side note, Firewire is not a very good interface for video. Your camera is worth better. You would probably save a lot of time and effort by investing in an HDMI-card/USBdongle instead.
Similar Topics
Dropped Frames after upgrading to Windows 11 (Hardware Compatibility)
by cbc 10/8/2026 10:56:39 PM(UTC)
Youtube Livestream stuttering, no dropped frames (General Discussion)
by DeanJohnsonProductions 4/24/2026 4:58:24 PM(UTC)
Feature Request: Expose Dropped Frames & Health Stats in API XML (Stream, Record, SRT) (Feature Requests)
by bulent_atlas 12/8/2025 4:46:20 PM(UTC)
Dropped frames in recording due to slow PC or Internet? (General Discussion)
by WILRI01 10/2/2024 4:15:35 AM(UTC)
BUG? Dropped frames counter max? (General Discussion)
by h2video.nl 5/13/2023 8:12:41 PM(UTC)
Massive Dropped Frames Via Screen Capture to Vmix (NDI)
by Dazzer89 10/3/2022 10:12:43 PM(UTC)
Dropped frames on input and external after VMix 25 update (General Discussion)
by Vince Beck 9/8/2022 3:37:49 PM(UTC)
Micro stutters/dropped frames (General Discussion)
by bobdrad 5/2/2022 5:29:50 AM(UTC)
vMixCall to Output - dropped frames (vMix Call)
by StudiovMix1 3/11/2022 1:58:46 AM(UTC)
very high Rendere Dropped Frames (General Discussion)
by ezoN 1/6/2022 1:01:03 AM(UTC)
Has anyone got 1080p50 working with no dropped frames? (NDI)
by nomski 9/3/2021 6:06:13 PM(UTC)
Record Button Turns Yellow on Dropped Frames (Feature Requests)
by aircooled76@gmail.com 4/23/2021 10:26:56 AM(UTC)
Render time spikes and dropped frames (General Discussion)
by tomtailford 4/22/2021 3:38:52 AM(UTC)
NDI dropped frames in VMIX capture only (NDI)
by ejkravetz 4/16/2021 5:27:09 AM(UTC)
NDI Dropped Frames (General Discussion)
by gujingc 4/16/2021 4:29:42 AM(UTC)
Dropped Frames - But Only MPEG2 (General Discussion)
by kjones9999 2/24/2021 7:29:34 AM(UTC)
dropped frames with Quadro RTX 4000 GPU (General Discussion)
by enigmothy 10/11/2020 5:49:16 AM(UTC)
NDI dropped frames from 2nd PC (NDI)
by Gunnar Hauth 8/25/2020 8:43:02 AM(UTC)
Simple NDI Setup, massive dropped frames (NDI)
by reezyfasheezy 7/19/2020 12:46:27 PM(UTC)
Dropped Frames and Latency (General Discussion)
by davenv 6/29/2020 1:43:02 AM(UTC)
Need help with flicker (or dropped frames?) (General Discussion)
by Pops 6/26/2020 2:31:24 AM(UTC)
SRT Source Dropped Frames? (SRT)
by Plamen 6/25/2020 12:59:00 PM(UTC)
dropped Frames with Decklink Duo2 and vMix 23.0.0.57 (General Discussion)
by newmans 6/8/2020 4:54:27 AM(UTC)
Renderer Dropped Frames on External Output (General Discussion)
by MickG 3/17/2020 12:19:45 PM(UTC)
Dropped frames in Headset device without having such? (Hardware Compatibility)
by noonsong 9/10/2019 2:26:25 AM(UTC)
Thousands of dropped frames (multicorder, cam input only) (General Discussion)
by ebjorno 7/20/2018 4:20:41 AM(UTC)
Dropped frames due to source framerate?? (General Discussion)
by spencerm24 6/17/2018 2:02:25 AM(UTC)
Dropped Frames Over NDI From macbook (NDI)
by nowski 12/15/2017 11:39:21 AM(UTC)
Multicorder dropped frames (General Discussion)
by nowski 11/7/2017 9:47:52 AM(UTC)
Dropped Frames, DueToSourceFrameRate, MAJOR Audio/Video Sync Issues when Editing, Please help! (General Discussion)
by Ragnvald 3/20/2017 1:33:18 AM(UTC)
