dgrimm
#1 Posted : Sunday, May 19, 2013 9:40:19 PM(UTC)
dgrimm
Is it possible to use IP cameras with vMix?
macjaeger
#2 Posted : Monday, May 20, 2013 5:51:37 AM(UTC)
macjaeger
Depends on what your ip-camera can output. I just have successfully tested an ip-cam that outputs a h264-encoded rtsp-stream, but i don't know if it also works with mjpeg-streams.
#3 Posted : Monday, May 20, 2013 8:22:20 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
vMix will work with some IP cameras that support the following:
Protocol: RTSP
Video: H264
Audio: AAC
There will be support for more IP cameras added in the next release, however the above requirements will remain.
dgrimm on 5/20/2013(UTC)
dgrimm
#4 Posted : Monday, May 20, 2013 2:59:53 PM(UTC)
dgrimm
Thanks Martin, looking forward to next release, any time frame
antardwip
#5 Posted : Thursday, February 6, 2014 6:20:02 AM(UTC)
antardwip
I am using a TP-Link SC3230 IP camera - unsuccessfully so far trying to connect within vMix. Can you please let em know if it is compatible, if so, what is the correct rtsp or whatever address?
We want sound and video from an IP camera within vMix - do you have any models you have tested with success you could recommend?
Thank you. Awesome software.
Similar Topics
CPU usage with IP cameras (NDI)
by Drdre 10/21/2023 9:29:08 AM(UTC)
Input IP cameras into vMix (General Discussion)
by Simsyuk 10/5/2021 9:19:54 PM(UTC)
HW Specs for vMIX for 8 ip Cameras with 2 output streams (Systems)
by retroip 1/20/2021 6:28:32 AM(UTC)
Using vMix on an entry level computer with IP cameras and frame dropping (General Discussion)
by GloryofGod 7/3/2018 2:18:36 AM(UTC)
Multicorder with IP cameras (Feature Requests)
by concerthall@drew.edu 3/15/2018 11:18:43 AM(UTC)
24.99 fps input from IP cameras (General Discussion)
by mcgrubso 10/28/2017 9:27:16 AM(UTC)
ONVIF PTZ other IP Cameras (Feature Requests)
by boris9831 12/16/2016 7:27:40 PM(UTC)
Compatible IP cameras over Internet with Audio (Hardware Compatibility)
by sandy6699 10/11/2016 9:52:47 PM(UTC)
IP Cameras? Automatic swich? (General Discussion)
by Hall3008 8/21/2016 10:29:06 AM(UTC)
Using Wireless HD IP Cameras for live stream ?? (General Discussion)
by tdurhamjr 9/15/2015 12:50:36 PM(UTC)
What IP Cameras Work? (General Discussion)
by mustangnaz 12/22/2014 1:05:42 PM(UTC)
can vMix ingest IP Cameras over Ethernet? (Hardware Compatibility)
by coskel22 8/11/2014 10:48:35 AM(UTC)
Uesing only ip cameras ? (General Discussion)
by Henny 7/18/2014 6:19:39 AM(UTC)
ip cameras (General Discussion)
by cambysys 2/26/2014 7:03:26 AM(UTC)
IP Cameras (Hardware Compatibility)
by dgrimm 5/29/2013 5:49:50 PM(UTC)
ip cameras? (General Discussion)
by fplus 11/14/2012 5:35:28 AM(UTC)
