IP Cameras? Automatic swich?
Joined: 7/31/2016(UTC) Posts: 69   Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
Joined: 2/14/2016(UTC) Posts: 118  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
If you want to switch from one cam to another and back again, you can use the Playlist option in vMix. After adding all inputs (cams), you can make your Playlist and tell vMix the time to switch. Using "loop" wil restart the sequence automatically.
 2 users thanked Mari for this useful post.
Here's an approach that would minimize it's impact on vMix, presenting a single source. I have some Grandstream GXV3762 cameras that are recorded by a Grandstream GVR3550 NVR. The GVR has an HDMI output. It can cycle through the various attached cameras, displaying each on the HDMI output for a preset amount of time. You could capture that HDMI output into vMix. You'd have a single source that was a constant cycle of cameras. The GVR can also display a programmable grid of cameras, making it a bit like a virtual monitor wall. There's a smaller, cheaper model of the GVR that would probably do the same thing. It just has smaller hard drive slots to received 2.5" hard drives. It's possible that other NVRs will do this sort of thing as well.
