Is there away to use this setup http://screencast.com/t/2zXx4pOezK and for the green screen replace with a image background? I know how to have a full image background as an input then place me over it. But not sure how to put the image in the back ground with this set up.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
1. First add the background to vMix as a separate input. 2. Click the i button under the input to open up the Input Settings 3. Under the MultiView tab select the camera from the first dropdown box.
You will now have combined the camera and the background into a single input. You can go back to the input settings for the camera and use the Colour Key tab to configure the chroma key settings.
You can then select that combined input within another input MultiView setup. (vMix supports up to two levels of MultiView in this way)
Martin vMix
