Hall3008
#1 Posted : Sunday, July 31, 2016 9:55:16 AM(UTC)
Hall3008
Croatia
Whether vMix supports this card Blackmagic DeckLink Duo 2? I see a set of written to support the DeckLink Quad 2 or give support and DeckLink Quad second
jhebbel
#2 Posted : Sunday, July 31, 2016 4:17:52 PM(UTC)
jhebbel
mashynewie2
#3 Posted : Monday, August 1, 2016 1:58:40 AM(UTC)
mashynewie2
Was thanked: 44 time(s) in 33 post(s)
This live stream was produced using a Decklink Duo 2 and vMIX
Works great.
http://huntertv.com.au/2...stars-of-newcastle-2016/
Hall3008
#4 Posted : Monday, August 1, 2016 3:54:17 AM(UTC)
Hall3008
Croatia
Tnx. That what I need to know.
MCPSStv
#5 Posted : Thursday, August 4, 2016 4:03:48 PM(UTC)
MCPSStv
Works great.
Just to clarify, using the Decklink Duo 2, you were able to have 5 simultaneous inputs in Vmix?
I ask because we got burned when we bought the BM Decklink 4k Pro.
mashynewie2
#6 Posted : Thursday, August 4, 2016 6:41:00 PM(UTC)
mashynewie2
Sorry I am mistaken, we used the Decklink Quad 2 which gave us 8 simultaneous inputs
The Decklink Duo 2 is only 4 inputs
The 5th connector on the Duo 2 is for a reference source and is not a video input
#7 Posted : Thursday, August 4, 2016 7:34:41 PM(UTC)
@ MCPSStv
Can you elaborate on how you got burned with the BM Decklink 4K Pro?
And also be aware the original Decklink Duo (which is still available from B&H) is only 2 Input 2 Output, you'll want to be sure you get the new Deckling Duo 2 for 4 I/O options (the same goes for the Quad and the new Quad 2).
Keith32
#8 Posted : Tuesday, August 23, 2016 7:42:26 AM(UTC)
Keith32
I plan to get the Blackmagic Design DeckLink Duo 2 for use with vMix. Will this allow simultaneously using 3 camera inputs and one output to feed the projector and Monitors?
The inputs will include PTZ cameras and maybe an NDI PC capture.
I will use an 8 line Mini Converter SDI Distribution to feed the monitors via SDI, then to SDI TO HDMI Mini Converters.
Thanks, Keith
kamal
#9 Posted : Wednesday, August 24, 2016 12:11:28 AM(UTC)
kamal
@Keith32
I just received my DeckLink Duo 2 and tested it with 3 camera inputs via 3 BMD Micro Converter (HDMI 2 SDI) and run well with no issue (no real production only testing). For low latency and better performance, I'm planning to get HDMI distributor, hook it to the HDMI on the graphics card and use two Micro Converters (HDMI2SDI and SDI2HDMI) to feed Projectors/Monitors and for external recording. Using the capture card as an output will increase the latency.
The only problem I got is when trying to send HDMI signal from other PC to the Micro Converter then to the DeckLink Duo 2. The Input is flickering not only in vMix but also in BMD Media Express. Don't know where the problem is: the card or the converter or the other PC.
Mathijs
#10 Posted : Wednesday, August 24, 2016 9:29:32 AM(UTC)
Mathijs
It can be your cabling. The duo and quad 2 are quite picky when it comes to getting a 1080P 50/60 signal input.
When you lower the frame rate on the other system to 25/30 the problem will be gone most of the time.
Similar Topics
Decklink Duo 2 - 3 External Outputs (Hardware Compatibility)
by Puawai Productions 6/27/2026 10:18:14 AM(UTC)
Green line at top and bottom when using DeckLink Duo 2 Fill/Key output in vMix (1080i59.94) (Hardware Compatibility)
by ken5o 2/14/2026 8:26:42 PM(UTC)
Issue Decklink Duo 2 and desktop video 14.3 (only legacy wdm input vmix) (Hardware Compatibility)
by julien 11/27/2024 12:14:34 AM(UTC)
Sending Key/Fill and Video from Decklink Duo 2. Is it possible? (Hardware Compatibility)
by fva 8/29/2024 2:09:37 AM(UTC)
Decklink Duo 2 Input Problem (Hardware Compatibility)
by dny18 5/12/2024 7:33:14 PM(UTC)
Problem with 2 Decklink Duo 2 cards (Hardware Compatibility)
by filmmaker75 2/5/2024 9:04:11 PM(UTC)
Decklink Duo 2 Output Settings (General Discussion)
by obcocav 5/22/2023 7:11:14 AM(UTC)
2X Decklink Duo 2 and 2X Sonnet Echo Express SE1 (Hardware Compatibility)
by EvilAsh80 2/16/2022 12:10:49 AM(UTC)
Dell PC distorted audio output to Decklink Duo 2 (Hardware Compatibility)
by ibwalkn 1/27/2022 5:25:38 AM(UTC)
DeckLink Duo 2 Not working (General Discussion)
by CyberPunk1232 11/27/2021 1:39:49 PM(UTC)
2 inputs working, 2 inputs not working with Decklink Duo 2 card (Hardware Compatibility)
by ThomasWallis 11/13/2021 5:36:18 AM(UTC)
Decklink Duo 2 dropping frames?? (Hardware Compatibility)
by KirenPollard 10/8/2021 6:28:58 PM(UTC)
Decklink Duo 2 dropping frames (Hardware Compatibility)
by svetotehnik 5/13/2021 5:04:02 PM(UTC)
Error with input from BlackMagic Decklink Duo 2 (Hardware Compatibility)
by gmm920 1/13/2021 2:24:13 AM(UTC)
No audio on first input of Decklink Duo 2 (Hardware Compatibility)
by rehofman 1/4/2021 8:50:41 PM(UTC)
Decklink Duo 2 Embedded Audio Output (Hardware Compatibility)
by ARSP 8/19/2020 10:57:04 AM(UTC)
BM Decklink Duo 2 or Magewell Pro Capture Quad SDI with Sony PXW (Hardware Compatibility)
by A_palmre 5/31/2020 6:32:10 PM(UTC)
Blackmagic Decklink Duo 2 and Sony EVI-HD1 (Hardware Compatibility)
by GraceMaryville 4/10/2020 7:55:21 AM(UTC)
BMD Decklink Duo 2 and Avipas PTZ camera (Hardware Compatibility)
by Riculus 1/19/2020 4:20:31 AM(UTC)
Atem vs Blackmagic design decklink Duo 2 (Hardware Compatibility)
Belarus Riculus 1/8/2020 1:04:45 PM(UTC)
[SOLVED] Decklink Duo 2 / Sonnet / Thunderbolt - Audio Problem (Hardware Compatibility)
by mundm 10/17/2019 2:12:37 AM(UTC)
Decklink Duo 2 set up (Hardware Compatibility)
by ElBurrito 9/6/2019 11:31:39 AM(UTC)
Can I capture 1080p60 using Blackmagic Design DeckLink Duo 2 and PTZOptics 12X 1080p HD-SDI ? (Hardware Compatibility)
by vhilly27 8/18/2019 4:58:46 PM(UTC)
Choppy Audio via Decklink Duo 2 only in vMix (General Discussion)
by NiBTour 7/13/2019 4:02:23 AM(UTC)
I have a may day. DeckLink Duo 2 issues (General Discussion)
by HJBProductions 12/1/2018 4:34:05 AM(UTC)
Blackmagic Decklink duo 2 (Hardware Compatibility)
by Studio279 7/8/2018 7:13:11 AM(UTC)
Question about the Blackmagic Decklink Duo 2 (Hardware Compatibility)
by dolfi 3/28/2018 9:16:52 AM(UTC)
Sonnet SE I + DeckLink Duo 2 - kinda working (Hardware Compatibility)
by MartLeib 11/10/2017 8:10:26 AM(UTC)
BMD Decklink Duo 2 (Hardware Compatibility)
by MJV_Bat 11/2/2017 8:08:45 AM(UTC)
Decklink Duo 2 Output.....Help! (Hardware Compatibility)
by Cris_AV 10/13/2017 12:54:07 AM(UTC)
