Hardware Compatibility
Can I capture 1080p60 using Blackmagic Design DeckLink Duo 2 and PTZOptics 12X 1080p HD-SDI ?
Joined: 7/17/2019(UTC) Posts: 3  Location: Cavite Thanks: 1 times
Not sure on the 12x model but we have the 30x PTZOptics and found that we have to use a Black Magic HDMI -> SDI converter because the PTZOptics only outputs A level SDI where the BM Duo 2 card expects level B level when doing 1080p50/60.
We've since moved this camera to a new BM 4 channel HDMI card and it works fine.
Joined: 11/29/2016(UTC) Posts: 75  Location: Italy Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Originally Posted by: mcollege  BM Duo 2 card expects level B level when doing 1080p50/60.
Are you sure?
My Decklink Duo 2 just arrived yesterday and tried my cam in all ports and noticed that only 2 ports are working. Configured the mapper to 4 inputs but only sdi 2 and 4 are only working.
Originally Posted by: rinaldo  Originally Posted by: mcollege  BM Duo 2 card expects level B level when doing 1080p50/60.
Are you sure? https://forum.blackmagic...opic.php?f=4&t=78578Fairly sure, I’ve got some Osprey Scallers and they output level A and don’t work at 50/60 . The black magic converters we have can be switch between A and B and will only work with B on this card.
