Bandit62
#1 Posted : Saturday, February 27, 2016 1:39:31 PM(UTC)
Rank: Guest
Groups:
I wish there was a builtin switcher like other similar programs, with the choice of turning it on and off, for those times when needed and when not needed....a simple switcher would be very handy at times.....I see two such programs here for vMix, but both were made for apple, and only one for windows.....it puzzles me, why a programmer would make an addon for a windows based program only usable on an apple machine.....I would think that a windows version be made first, then the apple version....not a great sales approach.....
Just my thoughts, but truely , a switcher would be a great thing to have..
Ed Tech
#2 Posted : Saturday, February 27, 2016 1:46:47 PM(UTC)
Ed Tech
You might consider setting up a midi controller to work as a control surface or "switcher" I bought the AKCMini for less than a $100, and with the little time I've had to experiment with it, I'm impressed with the controller and the whole midi concept. Beside, i believe the midi controller to be a cheaper, faster, more secure option....at least for what I do.
Hope that helps,
Video Dave
#3 Posted : Saturday, February 27, 2016 6:32:37 PM(UTC)
Video Dave
Same here, although I use the Numark Orbit (under $40.00) for my "switching'.
Bandit62
#4 Posted : Sunday, February 28, 2016 8:31:49 PM(UTC)
Rank: Guest
Groups:
I am a conventional person...I like the the look of a professional video switcher....hate having to remember which button does what....with a standard design video switcher, all I have to is look and I know.....simple layout, just like the vMix hardware switcher....there are two software switchers available, but the one I like is for use on an ipad....what I would like is a builtin one like VJDirector2......they have one that adds buttons as you add inputs, so it only has the same amount as the inputs...vidblaster does the same thing, but does not have a 'T' bar....same as Livestream Studio...theirs is builtin, rather than a Third Party plugin...
ask
#5 Posted : Sunday, February 28, 2016 10:20:20 PM(UTC)
ask
Why not use the Web controller. Set your shortcuts up with a descriptive title and it makes life easy. Also remember you can choose which shortcuts appear in the controller which you cannot do in the other programs you mentioned.
Bandit62
#6 Posted : Tuesday, March 1, 2016 7:01:07 PM(UTC)
Rank: Guest
Groups:
I use that sometimes, ...I was trying to get some code to design a GUI to replace the one it has.....I remember there was a program I had where I did that with another piece of software, but just can't seem to be able to put my hands on it....neither can I remember the name....but a simple switcher will be very nice.....
Similar Topics
[COMERCIAL] YourDirectorAI Switcher (3rd Party Software and Development)
by pmartin 11/25/2024 10:33:36 AM(UTC)
Separate Audio Mixer / Video Switcher Integration (General Discussion)
by BriarPatchMedia 6/26/2024 11:54:45 AM(UTC)
Hardware Video Switcher Question (General Discussion)
by kismetgerald 4/2/2024 8:27:35 PM(UTC)
TYST TY-1500HD Switcher Reset (General Discussion)
by Global-Livestream 10/24/2023 1:58:10 AM(UTC)
auto topic switcher/rotater? (General Discussion)
by barryondeck 2/8/2023 2:25:27 AM(UTC)
Using a Roland v1hd switcher with Vmix (General Discussion)
by Rick C. 12/31/2022 9:55:27 AM(UTC)
BM 20x20 router used as upstream switcher? (General Discussion)
by VideoE 5/29/2022 11:02:41 AM(UTC)
WinWet HY-SMP 880 Replay Switcher (Hardware Compatibility)
by Alain Lahaye 4/28/2022 8:49:25 PM(UTC)
Portable Live Production Switcher (Systems)
by applerox 1/7/2022 5:23:24 AM(UTC)
Recommendations on video switcher with VMIX (General Discussion)
by sojorner 10/19/2021 12:37:19 PM(UTC)
NewTek RS-8 switcher (Hardware Compatibility)
by NYC74 11/14/2020 5:19:37 AM(UTC)
Data video switcher (Hardware Compatibility)
by Dharmie 11/8/2020 7:49:05 PM(UTC)
Streaming switcher as vMIX USB 3.0 capture partner (3rd Party Software and Development)
by iamben 11/5/2020 5:07:49 PM(UTC)
Auto-video switcher (sound trigger) (Feature Requests)
by FisheyesProduction 9/25/2020 8:16:57 PM(UTC)
Do I need an input switcher with vMix (General Discussion)
by PhoenixDigital 8/13/2020 4:11:25 AM(UTC)
How to send video out to an hdmi switcher (General Discussion)
by laker_42 6/12/2020 7:16:47 AM(UTC)
VMix Audio Controlled Switcher (General Discussion)
by millst 12/20/2019 12:40:14 PM(UTC)
Virtual Switcher Layout (Feature Requests)
by micca54 10/30/2019 11:08:47 AM(UTC)
Build a mini switcher and stream system for 4 SDI HD camcorder. (Systems)
by ilfsn 6/16/2018 12:54:34 PM(UTC)
Build a mini switcher and stream system for 4 SDI HD camcorder. (Hardware Compatibility)
by ilfsn 6/16/2018 12:13:08 PM(UTC)
32 Input Switcher/Control Surface from X-keys 128 (Hardware Compatibility)
by David_in_Philly 4/11/2018 5:05:35 PM(UTC)
NDI Studio-- but Switcher across the country (NDI)
by rowby 2/24/2018 7:06:04 AM(UTC)
vMix 4K Live Production & Streaming Turnkey Switcher - 9 Inputs HD-SDI/HDMI For Sale (General Discussion)
by DoyleTX 9/13/2017 6:39:46 PM(UTC)
cheap hd-sdi cctv switcher (Hardware Compatibility)
by gt351 8/18/2017 1:03:00 AM(UTC)
Globecaster/Trinity CS-1000 Control Switcher (General Discussion)
by todd.hall@rcsdk12.org 4/1/2017 10:39:43 AM(UTC)
Wirecast hardware switcher (3rd Party Software and Development)
by AElli 9/1/2016 4:09:11 AM(UTC)
Help me design a live 2 Camera Switcher system (General Discussion)
by geoffreydean 1/15/2016 11:27:04 AM(UTC)
4 Port HDMI capture card for less than $100? Yes with external switcher, Works Decently 2.2sec black (General Discussion)
by darp 7/17/2015 5:43:01 PM(UTC)
[NEW!] vMix Audio Controlled Switcher! (NjastadCom) (3rd Party Software and Development)
by Sondrey 5/4/2015 5:06:28 PM(UTC)
We need Next Transition Tie function like hardware switcher's have. (General Discussion)
by pilgrims1 1/21/2015 1:07:58 PM(UTC)
