josue83
#1 Posted : Wednesday, September 23, 2015 7:46:08 PM(UTC)
josue83
Suggestions: 1) would be perfect to have the option of using entries in a single row or in two, as this has become a bit disoriented when we have small monitors. 2) The best we could do with the "Triggers" is to remove the milliseconds and convert in seconds since a limit of 30 is obsolete. 3) It is urgent to add a "Trigger" "CurrentSong" to play next in every time we use a "Overlay".
Sugerencias: 1) sería perfecto tener la opción de utilizar entradas en una sola fila o en dos, ya que esto se ha vuelto un poco desorientado cuando poseemos monitores pequeños. 2) Lo mejor que pudieramos hacer con los "Triggers" es eliminar los milisegundos y convertirlos en segundos ya que un limite de 30 es obsoleto. 3) Es urgente añadir un "Trigger" "CurrentSong" para poder reproducir next en cada vez que utilicemos un "Overlay".
Similar Topics
Motherboard Suggestions For New Build (Hardware Compatibility)
by TurboUK 1/11/2024 3:17:13 AM(UTC)
Zoom, issues/suggestions/requests for some minor improvements (Beta Discussion)
by richardgatarski 11/16/2023 5:49:41 AM(UTC)
Using NUC form factor PC as a Backup ? - Suggestions needed! (General Discussion)
by LucaL 1/10/2023 11:28:04 PM(UTC)
Hardware suggestions for vMix (Hardware Compatibility)
by marvelsferb7 9/24/2021 1:58:04 AM(UTC)
Suggestions/Observations/Questions (Feature Requests)
by snss 8/25/2020 12:22:14 AM(UTC)
Sports round timer suggestions (General Discussion)
by Andrew 7/20/2020 1:01:04 AM(UTC)
video tutorial suggestions (General Discussion)
by mbreese 6/9/2020 3:08:12 PM(UTC)
Suggestions please: Same show two different locations (General Discussion)
by LucaL 6/6/2020 12:45:29 AM(UTC)
Mixing Deck / Audio Interface Suggestions (Hardware Compatibility)
by hidavid 6/2/2020 10:19:53 PM(UTC)
Hardware Suggestions (General Discussion)
by kilerb 5/8/2020 1:40:15 PM(UTC)
Recording Quality - Need Suggestions or Other Options (General Discussion)
by datguyrob 4/15/2020 1:50:36 PM(UTC)
Some suggestions (Feature Requests)
by cmarangon 9/5/2019 6:48:48 AM(UTC)
Suggestions for an all NDI PC (Systems)
by madido 2/16/2019 1:44:27 AM(UTC)
Suggestions for 4K PCIe card add on, please? (General Discussion)
by ProSonas 1/21/2019 5:45:14 PM(UTC)
Play replays without setting an outpoint + more questions/suggestions (Instant Replay)
by rawland 1/16/2019 12:37:26 PM(UTC)
Need Urgent Camera Suggestions (General Discussion)
by mnortham 1/9/2019 9:12:08 AM(UTC)
Small Church Setup for vMix - Hardware Suggestions (Hardware Compatibility)
by zachuntley 5/3/2018 3:57:31 PM(UTC)
Need some suggestions??? (General Discussion)
by sfn123 3/1/2018 10:18:09 AM(UTC)
Camcorders, Cameras, Webcams suggestions (Hardware Compatibility)
by stampersplus 9/29/2017 11:48:23 AM(UTC)
Trying to Automate a Complicated Sequence-- Any suggestions (General Discussion)
by kjones9999 8/16/2017 10:31:59 PM(UTC)
SDI or HDMI Camera suggestions (General Discussion)
by andy2020 6/28/2017 9:32:41 AM(UTC)
Better incoming phone call options (Suggestions Please) (General Discussion)
by GoGo 6/23/2017 12:30:35 PM(UTC)
WebRTC Non-Cloud (And other WebRTC Suggestions) (Feature Requests)
by mashynewie2 2/11/2017 9:18:15 PM(UTC)
64bits VST3 on vMix 19 suggestions (Feature Requests)
by PFBM 12/23/2016 9:22:17 AM(UTC)
USB HDMI 1080p Capture Dongle Suggestions (Hardware Compatibility)
by nethfel 12/20/2016 12:51:32 PM(UTC)
Safe Areas - Submit Your Suggestions (Feature Requests)
by vmixsupport 12/14/2016 12:33:54 AM(UTC)
Laptop suggestions (Hardware Compatibility)
by Braindead 11/29/2016 2:58:55 PM(UTC)
Replay suggestions and feature requests (Instant Replay)
by DC Mike 1/28/2016 10:47:01 PM(UTC)
Suggestions for SSDs to use with Vmix Go Base (Systems)
by screamn 8/16/2015 10:35:17 PM(UTC)
Suggestions/Experience at low cost and software biased multicam vMix news setup (General Discussion)
by darp 6/7/2015 9:48:39 PM(UTC)
