claudio
#1 Posted : Friday, February 20, 2015 10:21:00 PM(UTC)
claudio
Hi Martin , as assigned on the keyboard the function of t bar?
#2 Posted : Saturday, February 21, 2015 1:06:16 AM(UTC)
@ claudio
There is no specific keyboard assignment for the T-Bar.
You can assign any key as a shortcut key for the transition you desire (Fade, Cut, Wipe or Zoom).
This is done in "Settings" (button at top right)
With "Shortcuts" option (near bottom of left menu in pop up window)
Click "Add"
Choose your Key, Function, Duration and Input (typically "Preview" if you are replicating the T-Bar function)
Hope that helps.
Egriswold
#3 Posted : Saturday, February 21, 2015 10:35:07 AM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
This was my solution http://forums.vmix.com.au/default.aspx?g=posts&m=11791#post11791
you don't have to use the web interface. The fader works standalone through a USB connection
Similar Topics
T-Bar roll replay with MIDI Controller does not work (Instant Replay)
by furtive 8/28/2024 9:42:07 AM(UTC)
T-bar plays video on vMix Replay (Feature Requests)
by mnmilos 4/1/2024 10:23:19 PM(UTC)
Flight stick throttle control assignable to T-Bar (Feature Requests)
by bremusound 12/8/2023 10:13:12 PM(UTC)
T-Bar API for the 15 Mix Inputs (Feature Requests)
by RichShumaker 12/17/2022 12:53:48 PM(UTC)
MIDI T-bar Fader Issue (Hardware Compatibility)
by JxM 4/8/2022 11:11:00 PM(UTC)
Issue with the replacement T-Bar in my X-Keys 124 (General Discussion)
by Egriswold 7/25/2021 11:57:50 PM(UTC)
Didn't get the T-Bar thingy (General Discussion)
by majorsky 6/14/2021 8:11:15 PM(UTC)
X-keys XKE-124 T-Bar (General Discussion)
by waldron18 5/24/2018 10:02:14 PM(UTC)
Does vMix really need the T-Bar version of X-Keys 128. (General Discussion)
by rowby 3/4/2018 2:52:48 PM(UTC)
SOLVED: Shortcut to determine what the T-Bar will do NEXT! (General Discussion)
by rowby 3/1/2018 10:10:31 PM(UTC)
T-Bar over Midi (General Discussion)
by mavik 4/25/2017 4:52:09 PM(UTC)
Overlays Tally and current Time below the T-Bar (Feature Requests)
by kamal 8/5/2016 1:17:05 PM(UTC)
X-keys XKE-124 T-Bar USB Keyboard (Instant Replay)
by cnolley 6/16/2016 5:54:03 PM(UTC)
Scripting for the t-bar? (3rd Party Software and Development)
by jhebbel 10/29/2015 7:49:01 AM(UTC)
Loving the MIDI Control! Made a Poor Man's T-Bar Controller (Showcase)
by sinc747 9/10/2015 10:54:47 PM(UTC)
T-bar while we are at it ?? (General Discussion)
by stevespaw 8/6/2015 8:21:35 AM(UTC)
Pausing transition (T-bar autotake simulation) (General Discussion)
by wwdv 4/21/2015 5:20:31 PM(UTC)
T-bar autotake (Feature Requests)
by wwdv 4/21/2015 5:12:11 PM(UTC)
More options for t-bar (setFader function and such...), and support for MIDI consoles (Feature Requests)
by vedranius 4/19/2015 7:34:46 AM(UTC)
vMix MidiMapper and stepping fader (t-bar)? (General Discussion)
by vedranius 4/15/2015 5:48:46 PM(UTC)
vMix Control Surface with a T-bar (General Discussion)
by Adriankey4 7/19/2014 1:04:36 AM(UTC)
control surface + T-Bar (General Discussion)
by dsharon 6/5/2013 3:33:19 AM(UTC)
