hellokitty
#1 Posted : Saturday, February 16, 2019 2:17:43 PM(UTC)
hellokitty
I have a 1080 TI and RTX 2080 coming tomorrow. I have a Dual Pc Streaming setup, so Based on NVENC there are 2 Chips in the 1080 TI and 1 Newer Version in the RTX 2080.Which card for which system? My friend said put the RTX 2080 in my Capture System. Any Thoughts? Thank You
spencerm24
#2 Posted : Sunday, February 17, 2019 6:10:50 AM(UTC)
spencerm24
I don't think it matters much if you go 1080 or 2080, Martin has said that the benefits aren't really seen in vMix.
that being said, I'd put the newer GPU with the most or fastest memory, in the system that does the most work. If you have a production PC and streaming PC, the production PC will do the most work. If you have a gaming PC and a streaming PC, I'd put it in the gaming PC, since games can utilize the 2080 more than vMix
thanks 1 user thanked spencerm24 for this useful post.
hellokitty on 2/17/2019(UTC)
Similar Topics
Video Inputs Turn Green on NVIDIA GPUs (Beta Discussion)
by maej 10/23/2025 1:18:36 AM(UTC)
GPU upgrade 4060 Ti 8GB to ??? (Systems)
by wolfbytes 7/31/2025 10:36:07 AM(UTC)
GPU not showing up in Diagnostics (Hardware Compatibility)
by cleeb73 7/30/2025 2:39:14 AM(UTC)
GPU Mem w/ NVIDIA RTX 5000 ada (Hardware Compatibility)
by broadcast_YYZ 7/10/2025 2:17:05 AM(UTC)
​AMD Radeon GPU Encoder Compatibility Issues in vMix (Hardware Compatibility)
by jiangang liu 6/18/2025 6:08:24 PM(UTC)
Replacing my AMD GPU (Systems)
by essem 6/15/2025 2:59:51 AM(UTC)
Maximum capability of Intel Ultra Arc iGPU (General Discussion)
by dexxer 1/9/2025 1:38:28 AM(UTC)
Game Ready or Studio driver for Nvidia GPU (Systems)
by amrhalawa 12/15/2024 7:55:15 PM(UTC)
hevc to YT with quadro GPU? (General Discussion)
by vmixLove33 10/9/2024 12:37:04 PM(UTC)
Audio Video Gradually Unsyncs Before & After GPU Upgrade (General Discussion)
by BoxMan_Actual 4/12/2024 3:00:35 AM(UTC)
GPU and/or Capture card? (General Discussion)
by TechDad 2/12/2024 5:46:42 AM(UTC)
Should vMix be reinstalled after GPU upgrade? (Hardware Compatibility)
by MarkNF82 12/17/2023 8:37:37 AM(UTC)
Best GPU for AV1 -- Nvidia 4000 series or Intel Arc? Or both? (Beta Discussion)
by sinc747 11/9/2023 3:17:48 PM(UTC)
Intel ARC GPU (Beta Discussion)
by iming_dj 10/20/2023 10:09:39 AM(UTC)
GPU Question Quadro RTX4000 vs Geforce RTX 4090 (General Discussion)
by mavik 10/6/2023 11:30:13 PM(UTC)
GPU Overload and Stuttering while recording & streaming (Hardware Compatibility)
by Binat 5/15/2023 9:13:58 PM(UTC)
GPU at 100% - Lightweight design (General Discussion)
by samirbridi 5/1/2023 5:57:45 AM(UTC)
vmix multi gpu SLI (Hardware Compatibility)
by formatta2003 4/14/2023 4:44:59 PM(UTC)
NVIDIA expands limit of NVENC encoders on consumer GPUs (Hardware Compatibility)
by paco3346 3/25/2023 12:38:14 AM(UTC)
GPU for Multicoder (Systems)
by WONGthink 2/25/2023 12:52:13 PM(UTC)
Is my GPU the bottleneck? GTX 1070 Ti (Hardware Compatibility)
by tylerpenn 2/7/2023 12:48:55 AM(UTC)
Why is vmix using 70% of my GPU when nothing is going on? (General Discussion)
by skirsch 11/3/2022 8:07:38 PM(UTC)
Quick decision help needed - Laptop with RTX3050 or RTX A2000 GPU? (Systems)
by Machtl 10/12/2022 9:22:01 PM(UTC)
GPU [quadro rtx 4000 8gb or rtx3060 12gb or RTX A4000 16gb) (Systems)
by flippy 7/20/2022 7:44:49 PM(UTC)
PC with GPU + 2 Decklink 8K Pro (Hardware Compatibility)
by mikavellini 7/1/2022 3:51:04 AM(UTC)
GPU compatibility (General Discussion)
by David1127 6/12/2022 12:32:25 PM(UTC)
GPU overload or insufficient router? (NDI)
by Gerrit Grobler 6/8/2022 6:13:50 PM(UTC)
These new laptop GPU's got me saying Whaaaaat? (General Discussion)
by RichShumaker 1/19/2022 3:11:45 PM(UTC)
vMix to utilize GeForce GPU (General Discussion)
by freefishday 12/29/2021 5:09:48 PM(UTC)
Does GT Ticker impose a GPU upgrade? (GT)
by kenmcl0126 12/6/2021 4:42:10 AM(UTC)
