amrhalawa
#1 Posted : Sunday, December 15, 2024 7:55:15 PM(UTC)
amrhalawa
Egypt
Game Ready or Studio driver for Nvidia GPUS
i'm very Confused about Selection Between the 2 Options for using the vMix
and i'm doing the two - Games and Creations
I Need A Final and Assured Response Please Depending on a Resources
Best Regards
ckvideo
#2 Posted : Sunday, December 15, 2024 10:44:30 PM(UTC)
ckvideo
Germany
Best Regards
technically the drivers are pretty similar, the main difference is, that "Game Ready" drivers are mainly tested with the big computer games, "Studio drivers" are tested with Adobe software and other "Creator" applications.
For vMix I would recommend using the "Studio driver", this is ok. A few more points to this:
  1. Take is easy with updating the nVidia driver, at least as fas as vMix is concerned. I'll update nVidia drivers 2 or 3 times a years. Thats fine.
  2. If your graphics card is pretty new, it might be useful to update more often, until this particular card has had some time to have all the driver issues fixed - if there are any at all.
  3. Be careful to remove the "GForce Experience" software package. This is more to make things easier for causal users, but sometimes gets in the way if you need more control.
  4. The updates that work together are Windows Updates, vMix Updates, nVidia Updates and videocard updates (aka Blackmagic). Depending on your setup, it is a good idea to plan an update day every now and than. Do the Windows updates, the nVidia update and the vMix update. If your videocard driver is working ok, leave it alone, unless it is getting older than a year or so.
  5. When updating videocard drivers, take the time to test all In and Out (SDI/HDMI) connectors throughout.
  6. Before causally updating vMix, please make sure you read the Release notes and decide if you need to update just two hours before a live show. (I would not recommend it...)
Hope this helps,
Christian
thanks 1 user thanked ckvideo for this useful post.
amrhalawa on 12/15/2024(UTC)
amrhalawa
#3 Posted : Sunday, December 15, 2024 10:53:59 PM(UTC)
amrhalawa
Egypt
Best Regards
Hope this helps,
Christian
Thank you very much for this informations I Appreciated 👏
vmixgreg
#4 Posted : Monday, December 16, 2024 8:17:00 PM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Actually, vMix recommends using "Game Ready" drivers, they are geared more towards processing "LIVE" or "real-time" video compared to "Studio" drivers which are optimized for processing saved data and rendering special effects.
(but as noted above, there is not a lot of difference between them and both will still work with vMix)
vMixGreg
thanks 1 user thanked vmixgreg for this useful post.
amrhalawa on 12/31/2024(UTC)
amrhalawa
#5 Posted : Monday, December 16, 2024 8:20:10 PM(UTC)
amrhalawa
Egypt
vMixGreg
That's why im so Confused for choosing which one many thoughts from diffrance Resources so i need it from the vMix Support Directly to be Assured!
ckvideo
#6 Posted : Tuesday, December 17, 2024 8:03:14 AM(UTC)
ckvideo
Germany
vMixGreg
Thanks Greg,
apparently there is no big difference, but I will change this in my training documents. Did you ever notice a difference somewhere / under certain conditions?
Do you know what kind of processing vMix offloads to the GPU ? It is still a bit of a mystery for me. I guess h.264 decoding runs on the GPU, maybe browser rendering in the Chrome engine, but what about the SpeedHQ codec from NDI sources? I am under the impression that this is handled by special CPU based code, but I might be wrong.
Thanks,
Christian
nikosman88
#7 Posted : Tuesday, December 17, 2024 8:18:43 AM(UTC)
nikosman88
Greece
Thanks,
Christian
Un-fortunatelly H264/H265 and other formats uses cpu only and this in some cases is not the ideal. There exist a feature request for allowing the user to check or not the "hw decode". https://forums.vmix.com/...-Hardware-Video-Decoding
There exist a workaround but also it has some negative effects. So "out of the box" even if you have the best GPU if you play 2-3 4k video same time in vmix,the middle range cpu will go "crazy",while gpu wont help even if it has the power to do it. Also Full NDI uses only cpu,when NDI HX decode by gpu
thanks 1 user thanked nikosman88 for this useful post.
ckvideo
#8 Posted : Tuesday, December 31, 2024 6:41:31 AM(UTC)
ckvideo
Germany
Thanks,
Christian
Thanks nikosman88,
this is pretty much what I guessed so far too. Maybe one of the friendly vMix admins here can shed some more light on this. I am not so deep in Windows Media Frameworks and GPU drivers (yet...).
Best,
Christian
