cambysys
#1 Posted : Wednesday, February 26, 2014 7:03:26 AM(UTC)
cambysys
Does anyone have some part numbers of Ethernet IP cameras that will work with VMIX.
As I understand it, the only protocol that VMIX understands is RTSP with the camera doing H264 encoding.
Am I correct that there is no way to connect a (cheap) ip camera that only does MJPEG encoding.
Thanks,
Frank
wwdv
#2 Posted : Wednesday, February 26, 2014 3:57:03 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
I bought a cheap PTZ camera on Ebay.
This camera works perfect with vMix and has no visible delay.
The Sony SNC-ZP550 (not cheap) is also working OK, but has a delay of almost a second.
Similar Topics
CPU usage with IP cameras (NDI)
by Drdre 10/21/2023 9:29:08 AM(UTC)
Input IP cameras into vMix (General Discussion)
by Simsyuk 10/5/2021 9:19:54 PM(UTC)
HW Specs for vMIX for 8 ip Cameras with 2 output streams (Systems)
by retroip 1/20/2021 6:28:32 AM(UTC)
Using vMix on an entry level computer with IP cameras and frame dropping (General Discussion)
by GloryofGod 7/3/2018 2:18:36 AM(UTC)
Multicorder with IP cameras (Feature Requests)
by concerthall@drew.edu 3/15/2018 11:18:43 AM(UTC)
24.99 fps input from IP cameras (General Discussion)
by mcgrubso 10/28/2017 9:27:16 AM(UTC)
ONVIF PTZ other IP Cameras (Feature Requests)
by boris9831 12/16/2016 7:27:40 PM(UTC)
Compatible IP cameras over Internet with Audio (Hardware Compatibility)
by sandy6699 10/11/2016 9:52:47 PM(UTC)
IP Cameras? Automatic swich? (General Discussion)
by Hall3008 8/21/2016 10:29:06 AM(UTC)
Using Wireless HD IP Cameras for live stream ?? (General Discussion)
by tdurhamjr 9/15/2015 12:50:36 PM(UTC)
What IP Cameras Work? (General Discussion)
by mustangnaz 12/22/2014 1:05:42 PM(UTC)
can vMix ingest IP Cameras over Ethernet? (Hardware Compatibility)
by coskel22 8/11/2014 10:48:35 AM(UTC)
Uesing only ip cameras ? (General Discussion)
by Henny 7/18/2014 6:19:39 AM(UTC)
IP Cameras (Hardware Compatibility)
by dgrimm 5/29/2013 5:49:50 PM(UTC)
IP Cameras (General Discussion)
Belarus dgrimm 5/19/2013 9:40:19 PM(UTC)
ip cameras? (General Discussion)
by fplus 11/14/2012 5:35:28 AM(UTC)
