hudsondp
#1 Posted : Friday, May 29, 2020 10:59:49 AM(UTC)
hudsondp
Canada
I am completely new to this software and I believe I lack the lingo to search online or witihin the forum for help.
I’m trying to stream workout videos and I just need to be able to cue multiple songs. My issue is once I cut another input in the song ends. Is there a another way I should be going about this. Almost like a DJ, does that make sense?
#2 Posted : Friday, May 29, 2020 3:22:19 PM(UTC)
Make sure to fully understand how the audio mixer works in vMix which is fully explained in plain english in the ... manual ! Very surprising, ain't it ?
https://www.vmix.com/help23/
You might also want to check vMix YouTube channel which contains hundreds of tutorials about each and every feature in vMix
Both are pretty much mandatory if you want to understand what you're doing
To give you a hint, I'd say each and every button in vMix will display a quick indication of what's it's there for simply with a mouse hover... Start with those in the audio section, some are activated, some are not... Check what happens when you switch from one input to another... You should see changes...
Have fun !
hudsondp
#3 Posted : Friday, May 29, 2020 8:53:09 PM(UTC)
hudsondp
Canada
If everything is fully explained in the manual why are their thousands of questions posted on the forum?
Didn’t appreciate the sarcastic tone. Why is there always an atmosphere of toxicity in anything equipment software related to this industry. I’ve watched a few tutorials on adding inputs none of them allowed me to clearly understand how to smoothly transition other inputs without sometimes stopping them sometimes. I’ve multilayered and sometimes it stops and sometimes it doesn’t.
Again I’m not sure I understand all the lingo to search or really understand the manual hence I thought I could reach out here and get assistance.
thanks 1 user thanked hudsondp for this useful post.
DJLTC on 10/14/2022(UTC)
#4 Posted : Friday, May 29, 2020 10:43:18 PM(UTC)
@ hudsondp
It can be somewhat overwhelming when first "learning the ropes" of vMix, so to speak, but 95% percent of the time, there is a way to do whatever it is you want vMix to do.
In this case, it is the "Automatically mix audio" feature or tic box (also the "double arrow" button in the vMix Audio mixer).
Essentially, when this is enabled, it means the "Audio follows Video" or is only LIVE when the Video is LIVE. When it is disabled, you have full manual control of the Audio, meaning you can turn it ON or OFF at anytime regardless of what is on screen.
This video helps to explain some of that:
I would also suggest using the List Input for adding a series of audio files to play sequentially:
https://www.vmix.com/help23/VideoList.html
dmwkr
#5 Posted : Friday, May 29, 2020 11:05:22 PM(UTC)
dmwkr
... and for videos, that you want to keep on playing after you have transitioned them from output to preview, you have to uncheck the "Automatically Pause after Transition" setting in the Input settings:
https://www.vmix.com/hel...nputSettingsGeneral.html
thanks 1 user thanked dmwkr for this useful post.
hudsondp on 5/30/2020(UTC)
ivanh3
#6 Posted : Saturday, May 30, 2020 2:19:21 AM(UTC)
ivanh3
Originally Posted by: hudsondp Go to Quoted Post
Just want to make sure I understand. You are streaming a workout video with a sound track so to speak? I have one idea that may work.
Download the app "NDI HX Capture". There is an IOS app, not sure about android. It will capture screen plus audio from your ipad or iphone.
Then add an input for NDI/desktop capture. Uncheck the automatically mix audio box. That means the audio from this input will not stop if it's not the current input.
Find an IOS app that will play your song list. Not sure about Canada, but in the states you have to be careful about streaming copyrighted material.
You would then control your playlist from the ipad/iphone.
I am sure there are a ton of other ways to do this as well.
Good luck!
hudsondp
#7 Posted : Saturday, May 30, 2020 2:22:03 PM(UTC)
hudsondp
Canada
Thanks so much guys will try these options when I get back on the program. Much appreciated.
Similar Topics
Count down timer and music in background (General Discussion)
by w7psk 8/31/2026 9:48:45 AM(UTC)
Mute live and play other music (General Discussion)
by w7psk 11/30/2025 4:37:46 AM(UTC)
Music - Like Photos for Audio (Feature Requests)
by RichShumaker 11/23/2023 12:13:03 AM(UTC)
Original sound for musicians comments, e.g. echo cancellation. [Fixed] (Beta Discussion)
by richardgatarski 11/10/2023 5:36:33 AM(UTC)
Music/background noise Removal (General Discussion)
by StixxAndStonesTV 8/30/2023 10:07:02 AM(UTC)
Syncing music and video from 2 different programs (General Discussion)
by Sev 8/4/2023 10:57:58 AM(UTC)
music and ausio spectrum visualiser (Feature Requests)
by riad 4/20/2023 5:31:33 AM(UTC)
Live stream audio drops out with organ or music (General Discussion)
by Delayne 11/17/2022 12:04:33 AM(UTC)
music under playlist (General Discussion)
by Bunkerboss 5/17/2022 10:14:47 PM(UTC)
Audio Dropouts with Music (General Discussion)
by Liberty Baptist Church 12/16/2021 4:25:51 AM(UTC)
Can vMix stream music from software mp3 player? (General Discussion)
by mikehende 8/6/2021 4:59:01 AM(UTC)
Vmix Call to live music band (vMix Call)
by kaduramos 7/23/2021 1:39:08 AM(UTC)
Instant Replay - Music sync with clips you play (Feature Requests)
by Hylkewolf 7/11/2021 10:55:21 PM(UTC)
Replay music fade in/out? (Instant Replay)
by ocrtalk 5/18/2021 1:07:55 AM(UTC)
Audio Distortion Playing Music on Zoom (General Discussion)
by rumainakoob 1/20/2021 7:40:52 PM(UTC)
Minimal music with Minimal gear (Showcase)
by synco 10/17/2020 2:50:26 AM(UTC)
Audio level normalization between speaking & music (General Discussion)
by m_elias 9/21/2020 1:57:02 AM(UTC)
Best Audio Settings for Live Musicians (vMix Call)
by siksikasoundz 6/15/2020 4:35:30 PM(UTC)
Mixing music (General Discussion)
by JohnKov67 6/3/2020 10:05:04 PM(UTC)
Background Music for Livestream to Youtube (General Discussion)
by VictorR 5/17/2020 11:57:51 AM(UTC)
Preshow graphic and music workflow (General Discussion)
by DynamoBen 5/2/2020 5:46:01 AM(UTC)
VmixCall audio to support Music. Proof inside (Feature Requests)
by ayo 4/24/2020 7:53:25 PM(UTC)
Remote Music DJ (vMix Call)
by bobbyb 4/24/2020 4:12:05 PM(UTC)
Live Music over VMixCall (vMix Call)
by Ragtec 4/13/2020 4:10:30 AM(UTC)
Live streaming and commerical music (General Discussion)
by StephenLee 12/10/2019 1:09:37 PM(UTC)
programming camera cuts to cue points on a music track. (Feature Requests)
by Cormac 6/17/2019 12:02:29 AM(UTC)
Music on youtube (General Discussion)
by givros 5/4/2019 5:55:12 PM(UTC)
Music and replay speed bug? (Instant Replay)
by Torg 4/18/2019 5:30:22 PM(UTC)
Music in replay (Instant Replay)
by Hall3008 3/26/2019 9:36:22 PM(UTC)
long distance collaboration on a musical project using vMix (vMix Call)
by RobLambert 1/22/2019 7:52:45 AM(UTC)
