Joined: 5/29/2020(UTC) Posts: 3  Location: Toronto Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
I am completely new to this software and I believe I lack the lingo to search online or witihin the forum for help.
I’m trying to stream workout videos and I just need to be able to cue multiple songs. My issue is once I cut another input in the song ends. Is there a another way I should be going about this. Almost like a DJ, does that make sense?
Make sure to fully understand how the audio mixer works in vMix which is fully explained in plain english in the ... manual ! Very surprising, ain't it ? https://www.vmix.com/help23/You might also want to check vMix YouTube channel which contains hundreds of tutorials about each and every feature in vMix Both are pretty much mandatory if you want to understand what you're doing To give you a hint, I'd say each and every button in vMix will display a quick indication of what's it's there for simply with a mouse hover... Start with those in the audio section, some are activated, some are not... Check what happens when you switch from one input to another... You should see changes... Have fun !
If everything is fully explained in the manual why are their thousands of questions posted on the forum?
Didn’t appreciate the sarcastic tone. Why is there always an atmosphere of toxicity in anything equipment software related to this industry. I’ve watched a few tutorials on adding inputs none of them allowed me to clearly understand how to smoothly transition other inputs without sometimes stopping them sometimes. I’ve multilayered and sometimes it stops and sometimes it doesn’t.
Again I’m not sure I understand all the lingo to search or really understand the manual hence I thought I could reach out here and get assistance.
 1 user thanked hudsondp for this useful post.
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ hudsondp It can be somewhat overwhelming when first "learning the ropes" of vMix, so to speak, but 95% percent of the time, there is a way to do whatever it is you want vMix to do. In this case, it is the "Automatically mix audio" feature or tic box (also the "double arrow" button in the vMix Audio mixer). Essentially, when this is enabled, it means the "Audio follows Video" or is only LIVE when the Video is LIVE. When it is disabled, you have full manual control of the Audio, meaning you can turn it ON or OFF at anytime regardless of what is on screen. This video helps to explain some of that: I would also suggest using the List Input for adding a series of audio files to play sequentially: https://www.vmix.com/help23/VideoList.htmlIce
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
 1 user thanked dmwkr for this useful post.
I’m trying to stream workout videos and I just need to be able to cue multiple songs. My issue is once I cut another input in the song ends. Is there a another way I should be going about this. Almost like a DJ, does that make sense? Just want to make sure I understand. You are streaming a workout video with a sound track so to speak? I have one idea that may work. Download the app "NDI HX Capture". There is an IOS app, not sure about android. It will capture screen plus audio from your ipad or iphone. Then add an input for NDI/desktop capture. Uncheck the automatically mix audio box. That means the audio from this input will not stop if it's not the current input. Find an IOS app that will play your song list. Not sure about Canada, but in the states you have to be careful about streaming copyrighted material. You would then control your playlist from the ipad/iphone. I am sure there are a ton of other ways to do this as well. Good luck!
Thanks so much guys will try these options when I get back on the program. Much appreciated.
