Luca
#1 Posted : Monday, February 20, 2017 11:06:19 AM(UTC)
Luca
Hi friends, we will resume the video project that we had moved away for lack of resources in 2016 ...
We're going to buy:
ASUS ROG GL552VW-CN244T
Intel® Core™ i7-6700HQ (2.6/3.5GHz, 6MB L3)
HD 1000 GB + 128 SSD - RAM 16GB -
Graphic nVidia GeForce GTX 960M(4 GB Dedicated)
for 1.300 euros
do you feel it a good choice?
Now the question that make us not sleep:
we had already purchased vMix Basic HD license and we used this software twice with Logitech HD Pro C920 WebCam in USB input,
now we would like to add a real videocamera to do close-ups with fading alternately with C920,
which video camera would you buy?
Are there video cameras that works with USB input?
Or in this case is mandatory a capture card?
In this case which capture card and which video cameras you should buy?
Thank you for patience, it is for noprofit organisation..
Luca
#2 Posted : Monday, February 20, 2017 11:50:20 AM(UTC)
Hi Luca
it's difficult to give you a reply. There are so many options, and it all depends on what you want to do and in which contexts you'll be working.
Why a laptop over a desktop? What is your motivation? It usually costs more and it also limits the type of equipments you can use with it such as capture cards. The ROG is a very good PC but maybe you don't need that for a webcam + one cam only. If money is limited, maybe there are others solutions to investigate.
USB is certainly the less interesting technology for multicam. However it can work. You might also consider cameras with RTSP protocol for example. But once again it all depends on your project and your budget. It is also possible to buy very cheap family HDMI camcorders which give pretty good results in most cases.
Take time to search the forum. You'll discover many options. Most of your questions have already been answered.
Guillaume
#3 Posted : Monday, February 20, 2017 2:27:46 PM(UTC)
@ Luca
AFAIK, there are no USB cameras other than Web cams, but there are options with various dongles and devices that will convert camera video signals like HDMI and/or SDI (or even analog RCA) to USB, so your first step should be to find a camera that meets your budget and quality standards (you'll need to set some parameters there for others to offer suggestions) and then figure out which device or dongle you will need to capture it into your laptop and vMix.
In terms of a choice of computers, no major issues there, other than the SSD might fill up fast depending on how it is being used...
(also, I think this thread would be better placed in "General Discussions" or "Hardware Compatibility")
Similar Topics
Hardware Converter: SDI to NDI and DANTE Ethernet Card (Hardware Compatibility)
by blopes 6/10/2026 7:40:05 AM(UTC)
Hardware Project: Custom TCP-API based vMix Controller (3rd Party Software and Development)
by fluozh 4/19/2026 11:36:07 AM(UTC)
hardware encoding with nvidia 5070 (Hardware Compatibility)
by Tim@tbenedict.com 11/4/2025 7:26:58 AM(UTC)
“Hardware Encoder Not Working with SRT Output in Replay Mode?” (SRT)
by bulent_atlas 10/11/2025 12:31:50 AM(UTC)
Direct support for BMD Micro Camera Control Hardware (Feature Requests)
by bcolgate 9/7/2025 3:55:37 AM(UTC)
Nvidia 5080 Hardware Encoding not working in VMix Streaming (SOLVED) (Hardware Compatibility)
by pdvdw 3/25/2025 2:55:04 AM(UTC)
Graphics Hardware is not supported (General Discussion)
by IceQB 1/29/2025 8:05:20 AM(UTC)
Compatibilidade de hardware (Hardware Compatibility)
by Filipe Motta 11/13/2024 1:24:32 AM(UTC)
Hardware for 13x NDI QHD/UHD streams (Systems)
by krzysztof 10/15/2024 3:05:28 AM(UTC)
Hardware Video Decoding (Feature Requests)
by Hazza 8/13/2024 11:16:53 AM(UTC)
Hardware Video Switcher Question (General Discussion)
by kismetgerald 4/2/2024 8:27:35 PM(UTC)
Compatible Hardware Controllers (Hardware Compatibility)
by CARPET MEDIA GROUP 3/28/2024 9:42:10 PM(UTC)
An Open hardware database (Feature Requests)
by hadphild 2/6/2024 8:28:50 PM(UTC)
Hardware Connection Log? (General Discussion)
by MarkNF82 10/15/2023 8:12:20 AM(UTC)
Poor encode quality of Hardware HEVC recording. (General Discussion)
by Ryzen6667 5/29/2023 3:54:09 PM(UTC)
Help with New machine and what vmix use most on hardware (Hardware Compatibility)
by sherlon 4/13/2023 1:30:11 PM(UTC)
Hardware Encoder Counter (Feature Requests)
by hadphild 3/25/2023 1:27:54 AM(UTC)
Hardware encoding (General Discussion)
by Troels1902 3/10/2023 12:08:12 AM(UTC)
Hardware discussion + NVIDIA encoders (Hardware Compatibility)
by casstoner27 2/10/2023 12:13:28 AM(UTC)
PC build Sept 2022 using available hardware (Systems)
by bitpod 9/20/2022 1:53:45 AM(UTC)
vMix Performance Issues - hardware limitation? (Hardware Compatibility)
Belarus beamic 7/31/2022 2:33:42 PM(UTC)
Hardware Encoding Issues on SRT (SRT)
by Guest 6/18/2022 4:25:17 AM(UTC)
Hardware de captura de vídeo (3rd Party Software and Development)
by GRIPROTV 5/23/2022 5:44:01 PM(UTC)
Request: Additional hardware external outputs (AUX) (Feature Requests)
by Owallen 2/16/2022 1:41:48 AM(UTC)
vmix hardware recommendations (Hardware Compatibility)
by manishkob 10/15/2021 8:53:31 PM(UTC)
Hardware suggestions for vMix (Hardware Compatibility)
by marvelsferb7 9/24/2021 1:58:04 AM(UTC)
vMix detects hardware change and indicates unregistered (General Discussion)
by ucf 9/7/2021 12:31:42 AM(UTC)
Hardware Encoder v Software Encoder (General Discussion)
by grantcoll 8/10/2021 1:43:27 PM(UTC)
vMix might hang on exit if SRT Input uses hardware decoder and... (SRT)
by richardgatarski 7/8/2021 3:38:59 AM(UTC)
vMix support for Intel Quick Sync hardware encoding (General Discussion)
by sadickes 6/28/2021 2:38:14 AM(UTC)
