fluozh
#1 Posted : Sunday, April 19, 2026 11:36:07 AM(UTC)
fluozh
Japan
Was thanked: 15 time(s) in 12 post(s)
Hello vMix Community,
I would like to share a project I’ve been developing: Iryx, a dedicated hardware control panel designed specifically for vMix workflows.
WIP working video is here: https://www.reddit.com/r..._custom_vmix_controller/
When I was working in esports production with vMix, I felt the need for a controller that offers easy-setup and reliability.
This device uses RP2040 and W5500 as base hardware, and communicates with vMix's TCP API.
It uses ACTS API and FUNCTION API so you do not need to configure Shortcut/Activators though vMix's settings section like other MIDI controllers. So this gives you Plug-and-Play for production.
Development is in very early stage, but basic functionality works including Cut,Fade, Stinger1~8 etc including Mix2~15 support.
Also I am thinking to integrate StreamDeck Module for more flexibility too.
TCP API though W5500's LAN port(DHCP supported) and USB-C connection(CDC-NCM) which will be detected as "Ethernet adapter".
Sorry for my English, Any feedback from the community would be greatly appreciated!
Best regards,
thanks 1 user thanked fluozh for this useful post.
Kotin on 4/19/2026(UTC)
Kotin
#2 Posted : Sunday, April 19, 2026 3:35:07 PM(UTC)
Kotin
Hi! First of all, huge respect for this project. As a fellow developer who also works extensively with the vMix TCP API, I completely understand and appreciate your approach.
Skipping the MIDI/Activator nightmare and using direct API commands for true Plug-and-Play is absolutely the right way to do it. The RP2040 + W5500 combo is a rock-solid choice for hardware, and the fact that you already support Mix 2~15 is incredibly useful for complex shows.
Do you have any plans to sell these units? I would love to know where I can buy one when it's ready.
Also, out of curiosity, since you work in esports production, how many instances of vMix do you typically run at the same time? I ask because I’ve been developing a centralized software tool called VRC (Video Recording Control Hub) designed to monitor and control multiple vMix machines simultaneously over the network. I recently posted a topic about it here on the forum. Since we share a similar vision on using the TCP API, I’d be really interested to hear your thoughts on it!
Keep up the fantastic work, and don't worry about your English — it's perfectly fine!
thanks 1 user thanked Kotin for this useful post.
fluozh on 4/19/2026(UTC)
fluozh
#3 Posted : Sunday, April 19, 2026 4:38:45 PM(UTC)
fluozh
Japan
Hi! I am planning to sell it on booth.pm with exporting option supported since this project is based in Japan.
But due to EU's import/export laws it may have restriction(RoHS) in Europe.
Great project! For my case, it is 2~8 instances at a time including Main Switching, Replay, Slides and images/movs, sub switching. But I'd say mostly 4 at average.
Thank you!
Kotin
#4 Posted : Sunday, April 19, 2026 5:05:27 PM(UTC)
Kotin
Thanks for the info! I will definitely keep an eye on booth.pm. Fortunately, the EU RoHS restrictions shouldn't be an issue for me here, so I'll be waiting for the release!
2 to 8 instances is a serious setup, and that is exactly the kind of environment I built VRC for. When you have Main, Replay, and separate graphics machines running simultaneously, keeping track of all the recording states, triggers, and macros centrally saves a lot of headaches.
If you ever have the time to test VRC in your typical 4+ machine workflow, your feedback as both a hardware developer and an esports engineer would be incredibly valuable.
Good luck with the final stages of your hardware development! I’ll be closely following your progress.
fluozh
#5 Posted : Sunday, April 19, 2026 9:39:13 PM(UTC)
fluozh
Japan
Thank you! It may be difficut to ship for Europe and California due to law appliance, but most of states should be fine. I'll let you know when I release it :)
I will definitely try VRC!
fluozh
#6 Posted : Thursday, November 19, 2026 4:48:49 PM(UTC)
fluozh
Japan
Small update. Supported ATEM Protocol too.
We will start selling this within this year inside of ASIA due to RoHS for now.
https://x.com/MikanseiDe...atus/2121877059102470483
https://x.com/MikanseiDe...atus/2122677474186473871
https://x.com/MikanseiDe...atus/2123070933409915035
