Hi Vmix forum!
I am having about 4-5 framedrops/min. when streaming with hardware encoder on, but it runs perfectly with hardware encoder off.
Does anyone have the same problem as I have?
Kind Regards, Troels.
PC specs:
CPU: Intel i9 7900x SSD: samsung mzvlw1t0hmlh GPU: RTX 3070 Ti MB: Supermicro C9X299-PGF 32G RAM (unknown)
Joined: 8/5/2015(UTC) Posts: 49  Location: Germany Thanks: 11 times Was thanked: 3 time(s) in 3 post(s)
Hi Troels1902,
the same here. HP Z640 Workstation XEON 16 physical cores and NVidia RTX 3070: Dropping frames with hardware encoding turned on.
Doesn't matter if turned on for recording or streaming.
Since you also use a RTX3070 I'm wondering if it could be the graphics card? Hm, maybe drivers? Need to check on them.
Luckily, the 16 physical cores have enough power to encode 3 streams and record several H264 files in parallel and vmix only shows about 20% use of the system.
Knut
