Troels1902
#1 Posted : Friday, March 10, 2023 12:08:12 AM(UTC)
Troels1902
Denmark
Hi Vmix forum!
I am having about 4-5 framedrops/min. when streaming with hardware encoder on, but it runs perfectly with hardware encoder off.
Does anyone have the same problem as I have?
Kind Regards, Troels.
PC specs:
CPU: Intel i9 7900x
SSD: samsung mzvlw1t0hmlh
GPU: RTX 3070 Ti
MB: Supermicro C9X299-PGF
32G RAM (unknown)
dasmedienatelier
#2 Posted : Friday, May 19, 2023 12:55:00 AM(UTC)
dasmedienatelier
Hi Troels1902,
the same here. HP Z640 Workstation XEON 16 physical cores and NVidia RTX 3070: Dropping frames with hardware encoding turned on.
Doesn't matter if turned on for recording or streaming.
Since you also use a RTX3070 I'm wondering if it could be the graphics card? Hm, maybe drivers? Need to check on them.
Luckily, the 16 physical cores have enough power to encode 3 streams and record several H264 files in parallel and vmix only shows about 20% use of the system.
Knut
Similar Topics
hardware encoding with nvidia 5070 (Hardware Compatibility)
by Tim@tbenedict.com 11/4/2025 7:26:58 AM(UTC)
Nvidia 5080 Hardware Encoding not working in VMix Streaming (SOLVED) (Hardware Compatibility)
by pdvdw 3/25/2025 2:55:04 AM(UTC)
Hardware Encoding Issues on SRT (SRT)
by Guest 6/18/2022 4:25:17 AM(UTC)
vMix support for Intel Quick Sync hardware encoding (General Discussion)
by sadickes 6/28/2021 2:38:14 AM(UTC)
Hardware encoding paramaters (General Discussion)
by rjwerth 1/15/2021 5:23:20 AM(UTC)
Hardware encoding on MacBook Pro (Hardware Compatibility)
by paulzenk 3/31/2020 11:21:24 AM(UTC)
SRT only with Hardware Encoding? (Fixed) (SRT)
by seb666 12/10/2019 7:39:20 PM(UTC)
Dual GPU hardware encoding. (Hardware Compatibility)
by kselltrum 11/5/2019 9:14:32 AM(UTC)
Hardware encoding without NVIDIA (Hardware Compatibility)
by carsco 11/26/2018 8:47:29 PM(UTC)
Use Stream 1 Quality and Hardware Encoding (General Discussion)
by sunkast 8/9/2018 10:23:53 AM(UTC)
Hardware encoding / streaming quality adjustments/improvements (General Discussion)
by tsulls 5/31/2018 4:38:09 PM(UTC)
Error when Hardware Encoding is selected for Facebook Live (General Discussion)
by HarleyHaynes 1/23/2018 8:30:57 PM(UTC)
Add secondary gpu hardware encoding (Feature Requests)
by Epag 7/3/2017 7:58:23 AM(UTC)
New Feature in 16.0.0.92 * NEW Hardware Encoding support for Streaming (Beta) (General Discussion)
by Slaver 10/3/2015 10:12:16 AM(UTC)
