Hardware Compatibility
Nvidia 5080 Hardware Encoding not working in VMix Streaming (SOLVED)
I have a new system and have been having issues with VMix hardware encoding for streaming from the beginning. The system functions in OBS perfectly and other software. Specifications: MSI 5080 Suprim CamLink Pro (connected to CPU PCIE LANE) Intel 285k CPU 64GB RAM Latest VMix software Latest Nvidia Drivers Symptoms: - Using VMix FFMPEG/FFMPEG2/FFMPEG6 to stream to any destination with Hardware Encoding ON causes the Stream to fail to start, error given in log: "No NVENC capable devices found". Streaming with Hardware Encoding OFF streams successfully, or when using CPU for hardware encoding. What I have tried: - Checked that VMix sees GPU in Settings - Performance tab - Ensured no other processes are using NVENC - Tried low latency and high performance modes - I tried disabling all hardware encoding in VMix and enabling again - Reinstalling VMix - Reinstalling GPU drivers - Streaming from OBS with hardware encoding (verified it works in OBS) - Recording in VMix MP4 with hardware encoding (verified it works, only streaming doesn't) I tried emailing VMix support and am still working with them, but no resolution after troubleshooting. Does anyone else have a 5080 and having issues with Hardware Encoding to Stream in VMix? LOG: Quote:FFMPEG1.Exited Streaming [h264_nvenc @ 056d2ba0] No NVENC capable devices found Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
libavfilter 6.105.100 / 6.105.100 libswscale 4. 7.103 / 4. 7.103 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio': Duration: N/A, start: 5925.428000, bitrate: 1536 kb/s Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 fps, 29.97 tbr, 10000k tbn, 10000k tbc Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s [tcp @ 056d7b40] TCP Buffer has been set to 6571008 bytes Stream mapping: Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (h264_nvenc)) Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (native)) Press [q] to stop, [?] for help [h264_nvenc @ 056d2ba0] Failed creating CUDA context for NVENC: 0x3e7 [h264_nvenc @ 056d2ba0] No NVENC capable devices found Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height [aac @ 056d6540] Qavg: nan [aac @ 056d6540] 1 frames left in the queue on closing Conversion failed!
UPDATE: VMIX Support said it seems only FFMPEG6 is supported by 50-series GPU's. Setting to FFMPEG6 in stream settings allows successful streaming.
