pdvdw
#1 Posted: : Tuesday, March 25, 2025 2:55:04 AM(UTC)
pdvdw
I have a new system and have been having issues with VMix hardware encoding for streaming from the beginning. The system functions in OBS perfectly and other software.
Specifications:
MSI 5080 Suprim
CamLink Pro (connected to CPU PCIE LANE)
Intel 285k CPU
64GB RAM
Latest VMix software
Latest Nvidia Drivers
Symptoms:
- Using VMix FFMPEG/FFMPEG2/FFMPEG6 to stream to any destination with Hardware Encoding ON causes the Stream to fail to start, error given in log: "No NVENC capable devices found".
Streaming with Hardware Encoding OFF streams successfully, or when using CPU for hardware encoding.
What I have tried:
- Checked that VMix sees GPU in Settings - Performance tab
- Ensured no other processes are using NVENC
- Tried low latency and high performance modes
- I tried disabling all hardware encoding in VMix and enabling again
- Reinstalling VMix
- Reinstalling GPU drivers
- Streaming from OBS with hardware encoding (verified it works in OBS)
- Recording in VMix MP4 with hardware encoding (verified it works, only streaming doesn't)
I tried emailing VMix support and am still working with them, but no resolution after troubleshooting.
Does anyone else have a 5080 and having issues with Hardware Encoding to Stream in VMix?
LOG:
FFMPEG1.Exited
Streaming
[h264_nvenc @ 056d2ba0] No NVENC capable devices found
Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
libavfilter 6.105.100 / 6.105.100
libswscale 4. 7.103 / 4. 7.103
libswresample 2. 8.100 / 2. 8.100
libpostproc 54. 6.100 / 54. 6.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 5925.428000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 fps, 29.97 tbr, 10000k tbn, 10000k tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
[tcp @ 056d7b40] TCP Buffer has been set to 6571008 bytes
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (h264_nvenc))
Stream #0:1 -> #0:1 (pcm_s16le (native) -> aac (native))
Press [q] to stop, [?] for help
[h264_nvenc @ 056d2ba0] Failed creating CUDA context for NVENC: 0x3e7
[aac @ 056d6540] Qavg: nan
[aac @ 056d6540] 1 frames left in the queue on closing
Conversion failed!
pdvdw
#2 Posted : Wednesday, March 26, 2025 1:02:14 AM(UTC)
pdvdw
UPDATE: VMIX Support said it seems only FFMPEG6 is supported by 50-series GPU's. Setting to FFMPEG6 in stream settings allows successful streaming.
