SRT
vMix might hang on exit if SRT Input uses hardware decoder and...
... the PC does not support hardware decoding (my guess).
Found this when a Preset created on a laptop with nVidia graphics was opened a laptop with only Iris Xe (i5-1135G7).
In the original Preset's Input that uses SRT as a Caller, hardware decoding was selected. When exiting on the Iris Xe without any changes, vMix (v24.0.0.62) just froze and had to be killed via the Task Manager. Took me a while to figure out that if I changed the Input, chose the same SRT source (from the list), deselected hardware decoding, and exited - it went fine. Repeated this step with v24.0.0.63, same result.
In all cases receiving the SRT stream worked fine (from a Listener sending with the default SRT stream quality). The issue is when exiting.
 1 user thanked richardgatarski for this useful post.
SRT
