batuhan
#1 Posted : Monday, August 29, 2022 8:07:38 PM(UTC)
batuhan
Turkey
hello youtube, at the end of a 2 hour live broadcast, we wait 2 minutes for the broadcast to close and start again for 2 hours, how do we do this automatically in v mix
Paul Camino
#2 Posted : Wednesday, August 31, 2022 5:48:21 PM(UTC)
Paul Camino
I'm not following exactly what you are asking here.
What part do you want to automate exactly? the 2 minute wait to close the broadcast, or just starting the broadcast again after 2 hours?
Regardless, this should be doable with triggers.
J0hnD0e
#3 Posted : Wednesday, August 31, 2022 6:49:41 PM(UTC)
J0hnD0e
Hello, I apologize for my bad English.
The maximum delay per trigger is 30 seconds. If you enter a larger value, such as 45 seconds, it is ignored. That is, if you set the trigger delay to 45 seconds, it will fire after 30
Need to use a script.
Best regards
Paul Camino
#4 Posted : Wednesday, August 31, 2022 7:26:25 PM(UTC)
Paul Camino
I guess I should have elaborated more, you can setup an input that is a 2hr countdown timer, then when that completes activate a trigger.
J0hnD0e
#5 Posted : Wednesday, August 31, 2022 9:45:53 PM(UTC)
J0hnD0e
Yes, it's possible, but it's best to use the timer in the script to read the Production Clock (broadcast time) and turn it off when it reaches 2 hours. Then wait for the desired interval (2 minutes) and run it again. From the Production Clock window, you can generate Input to the vmix project. I can’t test the idea, vmix is only at work, and I’m on vacation right now.
Best regards
PS. UserPostedImage
Similar Topics
Vimeo alternative live broadcast platform? (3rd Party Software and Development)
by can88 2/26/2024 11:17:12 PM(UTC)
NDI stopped working during the live broadcast. (NDI)
by kuuminsh 11/24/2023 5:34:16 PM(UTC)
command block during live broadcast (General Discussion)
by Matou 12/14/2020 9:16:48 PM(UTC)
Using RaspberryPi to automate live broadcast elements!!!! (GT)
by MaverickLan 12/20/2019 11:14:25 PM(UTC)
Using RaspberryPi to automate live broadcast elements (General Discussion)
by MaverickLan 12/19/2019 11:22:08 PM(UTC)
Scheduling Facebook Live broadcasts (General Discussion)
by bobdoyle 10/31/2017 2:33:27 PM(UTC)
Facebook Live Broadcast (General Discussion)
by tschmitz1155 3/22/2017 10:32:39 AM(UTC)
Newblue's Titler Live Broadcast goes NDI (3rd Party Software and Development)
by DWAM 1/5/2017 6:33:53 AM(UTC)
vMix and ATEM TV studio setup - Live broadcast for TV station (General Discussion)
by Siroki 9/29/2016 5:06:27 PM(UTC)
Facebook Live Broadcast Video-Audio Sync (General Discussion)
by GeorgeR 5/28/2016 8:46:27 PM(UTC)
NewBlue Titler Live Broadcast Supports NDI (General Discussion)
by ask 4/21/2016 8:06:44 PM(UTC)
Live Broadcasting Production Checklist Help (Hardware Compatibility)
by abdonsara 7/1/2014 9:45:41 PM(UTC)
