Jeremyjo
#1 Posted : Thursday, October 9, 2014 4:36:58 PM(UTC)
Jeremyjo
I just installed latest released version of vMix (14.0.25?) and now Desktop Capture doesn't seem to work. It connects, but all I get is a static image of what was playing on the remote computer when the utility connected.
Is this a known issue? Will there be an update soon? How do I get back to the previous version if needed?
Jeremy
Damn2Good4U
#2 Posted : Thursday, October 9, 2014 9:17:52 PM(UTC)
Damn2Good4U
I actually thought the problem has to do with my PC..
Seeing this post here made me tried the Desktop Capture once again and since updating to v14.. I cant see any other PC outside "This Computer"
Is this a bug or what?
Pls SOS!
#3 Posted : Thursday, October 9, 2014 10:32:06 PM(UTC)
There are no known issues with desktop capture, what is the version of the desktop capture program you have running on the other PC?
If you can't see the computer in the list you will need to double check your firewall settings.
Instructions here:
http://www.vmix.com.au/help14/DesktopCapture.html
Damn2Good4U
#4 Posted : Friday, October 10, 2014 7:17:43 PM(UTC)
Damn2Good4U
Instructions here:
Is it a must to have vMix installed on the remote PC or I can just use the vMix Desktop Capture which was exactly what I did...
But running the desktop capture under the instance of having vmix installed on both machine works...
Does this implies that the need for vMix Desktop Capture standalone software is no longer needed?
Rottimmy
kjpcrane
#5 Posted : Saturday, October 11, 2014 8:46:42 AM(UTC)
kjpcrane
i also had same problem and it was the fire wall on the other pc
Similar Topics
vMix Desktop Capture - from vMix Install vs DL from vmix.com (General Discussion)
by sinc747 2/6/2026 7:16:11 AM(UTC)
Vmix 4k with Desktop Capture over Zoom (General Discussion)
by JohnUK 10/8/2025 12:31:50 AM(UTC)
Desktop Capture for vMix (NDI)
by masaru 9/24/2025 5:00:57 PM(UTC)
Sudden stop of Desktop capture (NDI)
by Covenant 9/8/2025 6:29:57 AM(UTC)
Reconnect Desktop Capture automatically (NDI)
by Bruce27 8/6/2025 6:41:52 AM(UTC)
Desktop Capture from a tablet (General Discussion)
by Gerrit Grobler 4/23/2025 2:07:30 AM(UTC)
vMix Desktop Capture Windows rights level? (NDI)
by nethfel 3/9/2025 2:52:17 AM(UTC)
vMix Desktop Capture for Ultra-wide Screens (General Discussion)
by Jamin 12/24/2024 3:57:38 AM(UTC)
Lag while using local desktop capture (General Discussion)
by Chihiro 12/23/2024 7:19:52 PM(UTC)
Desktop Capture for NDI 27.0.0.3 Issue (NDI)
by hmimura 12/1/2024 6:38:28 AM(UTC)
Desktop Capture shows black screen (NDI)
by cjmccoll 3/9/2024 7:00:17 PM(UTC)
Desktop Capture Shortcuts (Feature Requests)
Belarus jsjoen7896 12/20/2023 2:34:11 PM(UTC)
vMix Desktop Capture NDI - Cannot resize (NDI)
by sjcaldwell 10/14/2023 4:14:38 AM(UTC)
Instant Replay using Local Desktop Capture (General Discussion)
by tgsteveo 10/13/2023 7:20:43 AM(UTC)
Local Desktop Capture Behaves Unexpectedly (General Discussion)
by tomthinks 8/11/2023 8:09:15 AM(UTC)
Mac desktop capture Developer Tools Access? (General Discussion)
by fatlip11 4/21/2023 5:59:39 AM(UTC)
Desktop Capture for Mac: Update? (NDI)
by DVE 3/10/2023 9:09:23 AM(UTC)
two-thirds local desktop capture Problem (NDI)
by coop 2/7/2023 11:44:59 PM(UTC)
Local Desktop Capture showing half of display and entire other smaller display (General Discussion)
by jonnybuttons 12/22/2022 9:57:39 AM(UTC)
Desktop capture/random skips to vmix laptop (NDI)
by _G3_ 12/20/2022 6:55:01 AM(UTC)
vMix Desktop Capture Crashes on Ventura on M1 Mac (NDI)
by BrentCavanagh 11/9/2022 3:45:55 AM(UTC)
vMix Desktop Capture (NDI)
by pesi 10/16/2022 9:12:12 AM(UTC)
desktop capture copartable with vmix 24 (Hardware Compatibility)
by emails4daniel 7/14/2022 5:25:56 AM(UTC)
Desktop Capture For Mac (NDI)
by Beloved 5/19/2022 1:26:48 AM(UTC)
How do I gain the highest resolution from desktop capture when using Chrome and Powerpoint? (General Discussion)
by Ken Robinson 3/30/2022 8:24:11 PM(UTC)
How to gain the highest resolution from desktop capture when using Chrome and Powerpoint (NDI)
by Ken Robinson 3/30/2022 5:56:23 PM(UTC)
vMix Desktop Capture with Win 11 (General Discussion)
by Browntown 3/30/2022 1:36:25 AM(UTC)
Desktop Capture "stutter" (General Discussion)
by whalerfan 2/16/2022 3:47:29 AM(UTC)
Desktop Capture with Keynote Presenter View? (NDI)
by revjgc 2/14/2022 5:54:14 AM(UTC)
NDI Desktop capture not working after Windows upgrade (NDI)
by Tech Support 2/9/2022 4:17:09 AM(UTC)
