Joined: 1/21/2013(UTC) Posts: 32  Location: Montana, US Thanks: 1 times
I just installed latest released version of vMix (14.0.25?) and now Desktop Capture doesn't seem to work. It connects, but all I get is a static image of what was playing on the remote computer when the utility connected.
Is this a known issue? Will there be an update soon? How do I get back to the previous version if needed?
Jeremy
I actually thought the problem has to do with my PC..
Seeing this post here made me tried the Desktop Capture once again and since updating to v14.. I cant see any other PC outside "This Computer"
Is this a bug or what?
Pls SOS!
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
There are no known issues with desktop capture, what is the version of the desktop capture program you have running on the other PC? If you can't see the computer in the list you will need to double check your firewall settings. Instructions here: http://www.vmix.com.au/help14/DesktopCapture.html
admin wrote:There are no known issues with desktop capture, what is the version of the desktop capture program you have running on the other PC? If you can't see the computer in the list you will need to double check your firewall settings. Instructions here: http://www.vmix.com.au/help14/DesktopCapture.html Is it a must to have vMix installed on the remote PC or I can just use the vMix Desktop Capture which was exactly what I did... But running the desktop capture under the instance of having vmix installed on both machine works... Does this implies that the need for vMix Desktop Capture standalone software is no longer needed? Regards, Rottimmy
i also had same problem and it was the fire wall on the other pc
