NDI
vMix Desktop Capture Crashes on Ventura on M1 Mac
Ever since I upgraded my M1 Mac to the new OS Ventura, when I go to launch vMix Desktop Capture 23.0.0.1 I have random crashes - usually at launch but sometimes a few minutes later. Has anyone else ran into this and/or found a way around it that worked for them? I assume because 23.0.0.1 is now a little dated that an update to the software may be required to handle the new OS but haven't been able to find any other reports here of this issue.
Here's a snippet of the crash report when it triggers:
Translated Report (Full Report Below)
Process: vMixDesktopCapture [10532] Path: /Applications/vMixDesktopCapture.app/Contents/MacOS/vMixDesktopCapture Identifier: com.vmix.vmixdesktopcapturendi Version: 1.0 (1) Code Type: X86-64 (Translated) Parent Process: launchd [1] User ID: 501
Date/Time: 2022-11-08 12:36:50.0635 -0500 OS Version: macOS 13.0 (22A380) Report Version: 12 Anonymous UUID: 3342A67A-D7F2-4735-9D9D-A570928B950D
Sleep/Wake UUID: EBA50454-5967-41D3-BD13-5F15EEEA8CBC
Time Awake Since Boot: 9700 seconds Time Since Wake: 17 seconds
System Integrity Protection: enabled
Crashed Thread: 11
Exception Type: EXC_BAD_ACCESS (SIGABRT) Exception Codes: KERN_INVALID_ADDRESS at 0x00003eadde6e6958 Exception Codes: 0x0000000000000001, 0x00003eadde6e6958
VM Region Info: 0x3eadde6e6958 is not in any region. Bytes after previous region: 68435445705049 Bytes before following region: 36636634224296 REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL commpage (reserved) 1000000000-7000000000 [384.0G] ---/--- SM=NUL ...(unallocated) ---> GAP OF 0x5f9000000000 BYTES MALLOC_NANO 600000000000-600008000000 [128.0M] rw-/rwx SM=PRV
Application Specific Information: abort() called
Joined: 6/2/2016(UTC) Posts: 40  Location: Everett, WA Thanks: 11 times Was thanked: 3 time(s) in 3 post(s)
I'm having trouble with vMix Desktop Capture on MacOS Ventura as well. I really hope they update it soon. I'll happily pay for it!
Same exact issue here. Mac mini M1, Ventura, vMix Desktop Capture randomly crashing. Any fix in the pipeline?
NDI
