craig
#1 Posted : Thursday, June 10, 2021 6:23:58 AM(UTC)
craig
After using the free version , and updating to HD , I have very low volume on my livestream. I'm not sure if I've hit the wrong button or what. I'm not very good at this type stuff but, I'm trying to get our little country church up to speed for the sick and elders. It was working well with the free version and then the volume went sour after downloading the new version. Thanks for any help
#2 Posted : Thursday, June 10, 2021 8:02:30 AM(UTC)
For what it is worth, there is no difference between the trial, free and licensed versions apart from restrictions in functionalities
Vince Beck
#3 Posted : Thursday, June 10, 2021 8:12:47 AM(UTC)
Vince Beck
Check you levels on the left of the program feed. Yu should be hitting the yellow. You can also buy effects like the Waves Ultramaximizer that will raise and limit your overall volume.
VMix also has a building in compressor that can be used in much the same way but is a bit more difficult to adjust.
Similar Topics
How to increase / decrease audio volume step by step using keyboard shortcuts in vMix 29? (General Discussion)
by medesan 1/15/2026 5:45:35 AM(UTC)
Bus Volume Fade oddities (Beta Discussion)
by Dist 11/30/2024 7:20:27 AM(UTC)
Set Headphones Volume (General Discussion)
by thomas.thielen12@gmail.com 10/23/2024 12:19:40 AM(UTC)
SetVolumeFade does not work (General Discussion)
by baelek 9/12/2024 9:23:00 PM(UTC)
Activator request : Input Volume Bus Mixer (Feature Requests)
by Victor Lp 3/28/2024 10:53:25 PM(UTC)
Better volume control of buses (Feature Requests)
by cody@raceontexas.com 10/14/2023 2:22:53 AM(UTC)
SetVolume Dial Show current volume % or db (Feature Requests)
by cody@raceontexas.com 10/13/2023 11:32:40 AM(UTC)
Add ability to adjust volume on individual videos within a list (Feature Requests)
by JazWolf27 7/26/2023 7:37:51 PM(UTC)
Multicoder record volumes (Feature Requests)
by hadphild 6/20/2023 8:24:07 PM(UTC)
External Output Volume control possible? (General Discussion)
by eersoy 3/8/2023 12:04:56 AM(UTC)
Help with SetVolume shortcut (General Discussion)
by DaveCS 2/26/2023 7:03:25 AM(UTC)
Device Volume (General Discussion)
by DThompson55 10/17/2022 4:08:08 AM(UTC)
Set volume on 16 the channels (Feature Requests)
by srioui 8/26/2022 10:15:59 PM(UTC)
Shortcut to Adjust Master (monitoring)Device Volume (Feature Requests)
by Gary 8/6/2022 9:03:14 AM(UTC)
InputVolume Event Activator doesn't support Dynamic Inputs (Feature Requests)
by foxy 7/29/2022 6:42:56 PM(UTC)
Additional Shortcut Functions Headphone volume (Feature Requests)
by UnderWaterFlying 6/15/2022 7:59:57 AM(UTC)
Input Audio to Bus Send - Volume Sends (Feature Requests)
by Gebbie 6/14/2022 2:33:52 PM(UTC)
Volume Controls (Feature Requests)
by Peter Cleaver 3/2/2022 3:14:16 AM(UTC)
SetVolumeFade on BUS AUDIO (Feature Requests)
by stevespaw 3/1/2022 6:37:41 AM(UTC)
Shortcuts / Scripting Set Master Volume (General Discussion)
by GregS 11/4/2021 9:15:53 AM(UTC)
Volume Threshold Trigger (General Discussion)
by xant 9/25/2021 12:39:03 AM(UTC)
Increase/Decrease Input Volume Incrementally via API (Feature Requests)
by greggibson 9/3/2021 12:08:32 PM(UTC)
device volume changing constantly (General Discussion)
by jcd 5/26/2021 2:08:11 AM(UTC)
Adjust input volume by mouse wheel (Feature Requests)
by digest0r 5/14/2021 5:30:38 AM(UTC)
Audio volume alert - send email or SMS (Feature Requests)
by romigo 5/13/2021 5:47:46 PM(UTC)
SetBusXVolumeFade in vMix (Feature Requests)
by Roi 4/24/2021 11:12:35 PM(UTC)
Volume / audio alert (General Discussion)
by KJPark 4/22/2021 6:38:17 PM(UTC)
master volume displays incorrectly in L channel *Solved* (General Discussion)
by karelholubicka 3/13/2021 12:03:52 AM(UTC)
SetVolumeChannelMixer shortcut with Fader (General Discussion)
by Harpert 1/18/2021 8:35:59 PM(UTC)
Dante and vMix volume issues (General Discussion)
by stpaulsmilaca 11/29/2020 8:29:43 AM(UTC)
