GregS
#1 Posted : Thursday, November 4, 2021 9:15:53 AM(UTC)
GregS
Canada
When using the Shortcut / scripting function "SetMasterVolume", Integer values between 0 and 100 are permitted.
Setting a Value of 0 or 100 produces the expected result, but any number in between does not work as expected.
For example, the following script:
' Set Volume Script =
'State variables
Dim state as new system.xml.xmldocument
Dim CurrentVolume As Double
Dim TextLine As String
TextLine = "Setting new volume of 40"
Console.WriteLine(TextLine)
API.Function("SetMasterVolume", Value:=40)
'=========Get Current Volume========
'Current status
state.loadxml(API.XML())
CurrentVolume = (state.SelectSingleNode("//audio/master/@volume").Value)
TextLine = "The Volume Actually Set is " + CurrentVolume.ToString()
Produces this result:
Starting Script "Set Volume"
The Volume Actually Set is 2.56
Stopping Script "Set Volume"
I Testes all of the values from 0 to 100 usning the following script:
' Test Volume Script =
'State variables
Dim NewVolume As Integer
Console.WriteLine("Set Volume,Actual Volume")
'=========Set Current Volume From 0 to 100========
For NewVolume = 0 To 100
API.Function("SetMasterVolume", Value:=NewVolume)
'Get Actual Volume========
TextLine = NewVolume.ToString() + "," + CurrentVolume.ToString()
Next
I plotted the results in Excel and got the following relationship:
Volume Settings Plot.jpg (24kb) downloaded 3 time(s).
I suspect that the input to the SetMasterVolume function is an integer, but is being interpreted by vMix as a float value.
#2 Posted : Thursday, November 4, 2021 5:33:10 PM(UTC)
Explained by Martin (4 years ago):
https://forums.vmix.com/...etVolume-scale#post45658
then turned into the knowledge base
https://www.vmix.com/kno...44/vmix-api-audio-levels
GregS on 11/5/2021(UTC)
GregS
#3 Posted : Thursday, November 4, 2021 9:47:17 PM(UTC)
GregS
Canada
@doggy:
Thank you for pointing me to that link. It was very helpful in explaining what is happening
I have a follow-up question regarding volume settings:
My goal is to make two shortcut keys to incrementally increase and decrease the final sound level so that it can be managed from the xMix Web Controller. Should I set the scripts to increment the sound level by a fixed amplitude, volume or decibel?
I have no audio experience, but my reading on the internet suggests I should use fixed volume increments, similar to a fixed distance on a fader. What do others suggest?
#4 Posted : Friday, November 5, 2021 12:58:35 AM(UTC)
Originally Posted by: GregS Go to Quoted Post
@doggy:
IMO just do a value +=1 for up and -=1 for down in the shortcuts (can change 1 to another for bigger steps )
GregS
#5 Posted : Friday, November 5, 2021 11:38:44 AM(UTC)
GregS
Canada
To close the loop on this topic:
I found that just changing the "Master Volume" by 1 was too coarse because about 4 clicks of the button went from full volume to mute.
I ended up converting the Audio>Master>Volume (Amplitude*100) to Volume using the formula:
CurrentVolume = ((CurrentAmplitude/100)^0.25)*100
. Changing this by 2 gave a comfortable resolution.
The final code is here:
' Decrease Volume Script =
'Input variable
Dim VolumeChange As Double = -2
'State variables
Dim CurrentAmplitude As Double
Dim NewVolume As Long
'=========Get Current Amplitude ========
'Current status
CurrentAmplitude = (state.SelectSingleNode("//audio/master/@volume").Value)/100
TextLine = "The current Amplitude is " + CurrentAmplitude.ToString()
'=========Convert Amplitude to Volume ========
CurrentVolume = (CurrentAmplitude^0.25)*100
TextLine = "The current Volume is " + CurrentVolume.ToString()
'=========Set New Volume========
NewVolume = CurrentVolume + VolumeChange
TextLine = "Setting new volume of " + NewVolume.ToString()
