Shortcuts / Scripting Set Master Volume
Joined: 10/20/2021(UTC) Posts: 5  Location: Ontario Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
When using the Shortcut / scripting function "SetMasterVolume", Integer values between 0 and 100 are permitted. Setting a Value of 0 or 100 produces the expected result, but any number in between does not work as expected. For example, the following script: Quote: '====================================== ' Set Volume Script = '====================================== 'State variables Dim state as new system.xml.xmldocument Dim CurrentVolume As Double Dim TextLine As String TextLine = "Setting new volume of 40" Console.WriteLine(TextLine) API.Function("SetMasterVolume", Value:=40) '=========Get Current Volume======== 'Current status state.loadxml(API.XML()) CurrentVolume = (state.SelectSingleNode("//audio/master/@volume").Value) TextLine = "The Volume Actually Set is " + CurrentVolume.ToString() Console.WriteLine(TextLine)
Produces this result: Quote: Starting Script "Set Volume" Setting new volume of 40 The Volume Actually Set is 2.56 Stopping Script "Set Volume"
I Testes all of the values from 0 to 100 usning the following script: Quote: '====================================== ' Test Volume Script = '====================================== 'State variables Dim state as new system.xml.xmldocument Dim CurrentVolume As Double Dim NewVolume As Integer Dim TextLine As String Console.WriteLine("Set Volume,Actual Volume") '=========Set Current Volume From 0 to 100======== For NewVolume = 0 To 100 API.Function("SetMasterVolume", Value:=NewVolume) 'Get Actual Volume======== state.loadxml(API.XML()) CurrentVolume = (state.SelectSingleNode("//audio/master/@volume").Value) TextLine = NewVolume.ToString() + "," + CurrentVolume.ToString() Console.WriteLine(TextLine) Next
I plotted the results in Excel and got the following relationship:  Volume Settings Plot.jpg (24kb) downloaded 3 time(s).I suspect that the input to the SetMasterVolume function is an integer, but is being interpreted by vMix as a float value.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
@doggy: Thank you for pointing me to that link. It was very helpful in explaining what is happening I have a follow-up question regarding volume settings: My goal is to make two shortcut keys to incrementally increase and decrease the final sound level so that it can be managed from the xMix Web Controller. Should I set the scripts to increment the sound level by a fixed amplitude, volume or decibel? I have no audio experience, but my reading on the internet suggests I should use fixed volume increments, similar to a fixed distance on a fader. What do others suggest?
Originally Posted by: GregS  @doggy: Thank you for pointing me to that link. It was very helpful in explaining what is happening I have a follow-up question regarding volume settings: My goal is to make two shortcut keys to incrementally increase and decrease the final sound level so that it can be managed from the xMix Web Controller. Should I set the scripts to increment the sound level by a fixed amplitude, volume or decibel? I have no audio experience, but my reading on the internet suggests I should use fixed volume increments, similar to a fixed distance on a fader. What do others suggest? IMO just do a value +=1 for up and -=1 for down in the shortcuts (can change 1 to another for bigger steps )
To close the loop on this topic: I found that just changing the "Master Volume" by 1 was too coarse because about 4 clicks of the button went from full volume to mute. I ended up converting the Audio>Master>Volume (Amplitude*100) to Volume using the formula: Quote:CurrentVolume = ((CurrentAmplitude/100)^0.25)*100 . Changing this by 2 gave a comfortable resolution. The final code is here: Quote: '====================================== ' Decrease Volume Script = '====================================== 'Input variable Dim VolumeChange As Double = -2
'State variables Dim CurrentAmplitude As Double Dim CurrentVolume As Double Dim NewVolume As Long Dim TextLine As String
'=========Get Current Amplitude ======== 'Current status Dim state as new system.xml.xmldocument state.loadxml(API.XML())
CurrentAmplitude = (state.SelectSingleNode("//audio/master/@volume").Value)/100 TextLine = "The current Amplitude is " + CurrentAmplitude.ToString() Console.WriteLine(TextLine)
'=========Convert Amplitude to Volume ======== CurrentVolume = (CurrentAmplitude^0.25)*100 TextLine = "The current Volume is " + CurrentVolume.ToString() Console.WriteLine(TextLine)
'=========Set New Volume======== NewVolume = CurrentVolume + VolumeChange TextLine = "Setting new volume of " + NewVolume.ToString() Console.WriteLine(TextLine)
