KevinBee
#1 Posted : Friday, February 5, 2021 3:36:17 AM(UTC)
KevinBee
I am new to VMix, I know my Cannon will not work. I'm looking to spend $600 or $700 dollars on a camera. Please recommend one.
SportsNetUSA.net
#2 Posted : Friday, February 5, 2021 4:39:56 AM(UTC)
SportsNetUSA.net
Depends on if you are looking for a DSLR or a camcorder. For a camcorder, look on Adorama or BH Photo, also try their used sections. I've bought used ones from both companies with no problems. Or look for a new close-out. In your stated price range, Sony, Canon and Panasonic camcorders should all work well.
Sony FDR-AX43 Ultra HD 4K Handycam Camcorder https://www.adorama.com/us1333721.html
If you use eBay, you might be able to find a Canon HF G21 at just over $600. Good camcorder, I have one. There are Canon G30 and G40 units on eBay but at that price range they might be pretty tired, and not worth buying.
I mainly use Canon camcorders, but if you can stretch your budget the Sony FDR-AX43 is 4K versus only 1080p for the Canon G21.
Do you have a capture device?
Josemite
#3 Posted : Saturday, February 6, 2021 2:20:44 PM(UTC)
Josemite
Probably not what you're looking for at all, but I'll post it here for somebody else that might come along.
I've been playing with using 3 'MEVO Start' cameras using NDI. For me these are a reasonable fit because I travel and they are small with built-in batteries (makes getting through TSA easier). Also, I don't mind being limited to 3 simple fixed angles. There is some tech in the MEVO APP for panning, zoom, live follow... but I don't use it.
Pros:
NDI with vMix
Small & simple
Wireless
Simultaneous recording to micro SD
Long battery life (6 hours)
Decent low light performance
Cons:
Need to buy separate network cable adapter (NDI WiFi unreliable in less than perfect conditions).
Have to use smartphone APP
APP to control device is a little clunky
Fixed lens (no depth of field)
thanks 1 user thanked Josemite for this useful post.
SportsNetUSA.net on 2/6/2021(UTC)
Similar Topics
vMix Sees NDI Cameras, But Black Screen Using Them For Replay? (NDI)
by JohnDoe415 5/15/2026 8:59:28 PM(UTC)
Help with adding RTSP cameras inputs through API Calls (General Discussion)
Belarus MartinC79 3/24/2026 2:51:41 AM(UTC)
[Open Source] TallyCCUPro: Bridge vMix Tally and CCU control to Blackmagic Cameras (3rd Party Software and Development)
by fiverecords 1/12/2026 7:59:59 PM(UTC)
PTZOptics Cameras Freeze over NDI (NDI)
by fcd 7/23/2025 4:07:59 AM(UTC)
Support 10 Replay Cameras & Flexible Storage (Feature Requests)
by gugacdb 5/30/2025 4:14:03 AM(UTC)
Timecode to Multicorder, Recorder and Cameras Hack (General Discussion)
by nowski 3/30/2025 12:15:01 AM(UTC)
Referece system for 20 NDI PTZ Cameras 2K @ 60 FPS (Systems)
by Bulldog 2/20/2025 9:33:26 AM(UTC)
Using multiple Insta 360 Link 2 cameras (Hardware Compatibility)
by DaleP 2/19/2025 10:48:38 PM(UTC)
Help Needed with SMTAV IP PTZ Cameras Positioning Issue (Hardware Compatibility)
by jacan sevada 1/13/2025 12:14:50 PM(UTC)
cameras are not showing in Vmix (General Discussion)
by daclifton 11/18/2024 12:58:52 AM(UTC)
How to record 6 cameras in sync and individually for post editing (General Discussion)
by John Hopkins 11/5/2024 8:26:19 AM(UTC)
TX Pictutres Versus Isolated cameras (General Discussion)
by Bfassbender 10/17/2024 11:28:45 PM(UTC)
NDI Cameras with black input (General Discussion)
by bscarbrough1903 9/2/2024 4:28:50 AM(UTC)
Streaming cameras (General Discussion)
by Carol McFarland 8/28/2024 5:25:40 AM(UTC)
NDI Cameras are showing up as just black on inputs (NDI)
by ab800 8/21/2024 6:32:37 AM(UTC)
Blurry cameras (General Discussion)
by George1 8/1/2024 7:19:16 PM(UTC)
Cameras 2-4 ghosted (Instant Replay)
by vjmandala 5/14/2024 2:56:32 PM(UTC)
2 or more NDI PTZ cameras (General Discussion)
by kabachin 5/9/2024 9:44:14 PM(UTC)
Troubleshooting CPU overload in Vmix with 3 cameras and Blackmagic capture card (General Discussion)
by GameWithSasha 3/27/2024 8:03:39 AM(UTC)
4 Cameras in USB Hub (Hardware Compatibility)
by elfabe028 2/14/2024 1:20:53 PM(UTC)
Issue with Create Input At This Position for PTZ cameras (General Discussion)
by TheBB 12/28/2023 6:12:18 AM(UTC)
Zoom support for Cameras / Calls / Audio Inputs NDI feeds (Beta Discussion)
by AElfTech 10/25/2023 3:12:50 PM(UTC)
CPU usage with IP cameras (NDI)
by Drdre 10/21/2023 9:29:08 AM(UTC)
It does not accept 3 cameras (General Discussion)
by apell 5/11/2023 6:17:06 AM(UTC)
HELP! I need to connect 8 logitech brio 4k cameras (Hardware Compatibility)
by ElianYmanol 4/24/2023 5:22:23 AM(UTC)
Prevent mistakes with PTZ Cameras (Feature Requests)
by Dan Whitaker 4/22/2023 6:50:02 AM(UTC)
Best Cameras for Long Event Streams (General Discussion)
by zachEEP 4/9/2023 4:03:46 AM(UTC)
Cameras Stopped Showing Up (General Discussion)
by spydervenom 3/9/2023 10:48:57 AM(UTC)
vMix and PTZ Cameras info request (General Discussion)
by LuMags 3/6/2023 3:05:09 AM(UTC)
PTZ Optics Cameras & Focus Presets (Hardware Compatibility)
by hparsons 1/25/2023 2:30:28 AM(UTC)
