David Canaday
#1 Posted : Saturday, May 23, 2020 9:41:20 PM(UTC)
David Canaday
my overlays do not scale in picture to picture what am i doing wrong
trying to over lay video in my main screen in top corner only shows part of the video does not scale I have the overlay in picture to picture IMG_0081.jpg (2,372kb) downloaded 8 time(s).
dmwkr
#2 Posted : Saturday, May 23, 2020 11:52:27 PM(UTC)
dmwkr
It would help if you'd post screenshots of your vMix screen and the Overlay settings.
dmwkr
#3 Posted : Sunday, May 24, 2020 1:49:49 AM(UTC)
dmwkr
You used zoom x and y, so that the scaling is not proportional. I don't think that's what you want. Then you moved the Pan X so far, that a part of the overlay is off the screen.
So, reset your zoom and pan settings and start from scratch. First you just use "Zoom", not zoom x and y separately, so that it scales proportional. Then you move Pan X (left/right) and Y (up/down) so that tha overlay is where you want it to be.
thanks 1 user thanked dmwkr for this useful post.
David Canaday on 5/24/2020(UTC)
Similar Topics
Overlays on Mix Inputs (Beta Discussion)
by Streamverse.tv 8/30/2025 7:49:09 AM(UTC)
New Overlays 5-8 Importing Stinger Settings From V28, Unable To Remove (FIXED) (Beta Discussion)
by kmedia 8/21/2025 3:21:06 AM(UTC)
Overlays cannot be activated by center buttons (Beta Discussion)
by ryxyz 8/16/2025 11:47:04 PM(UTC)
2 request - NDI|HX3 and NDI Overlays (Feature Requests)
by mikeborschow 7/5/2025 6:25:14 AM(UTC)
Camera Overlays (Feature Requests)
by calamityjane 6/5/2025 2:20:09 AM(UTC)
Changing Overlays in vMix 4K (General Discussion)
by KnoxTrinity 5/19/2025 12:45:18 AM(UTC)
Suggestion for Overlays (Beta Discussion)
by gugacdb 11/9/2024 3:11:57 AM(UTC)
"Shortcuts only" sringers/overlays on sub mixes (General Discussion)
by spinfold 10/12/2024 10:25:38 PM(UTC)
Overlays Cutting on Scene Transition (General Discussion)
by ceejperilous 3/31/2024 4:32:31 AM(UTC)
8 Overlays vs 4 PLEASE (Feature Requests)
by cody@raceontexas.com 3/15/2024 11:41:54 PM(UTC)
vmix scripting overlays (General Discussion)
by Kekso_10 10/23/2023 11:31:39 PM(UTC)
More then 4 overlays (Feature Requests)
by cody@raceontexas.com 10/22/2023 11:43:36 AM(UTC)
Overlays sticking on after playing.... (Beta Discussion)
by cody@raceontexas.com 10/20/2023 12:12:17 AM(UTC)
Is it possible to keep Overlays in Preview only? (General Discussion)
by Justingonz 9/8/2023 7:50:48 AM(UTC)
Overlays over a Mix Output (Feature Requests)
by rjmurdock 5/9/2023 8:47:22 AM(UTC)
GT Title overlays don't animate out on deactivation (unless I create a shortcut)??? (Feature Requests)
by ProducerAnywhere 5/3/2023 8:34:03 AM(UTC)
Aliasing in Overlays (General Discussion)
by rjwerth 3/10/2023 1:49:16 AM(UTC)
"Output" input always bring all the overlays (General Discussion)
by Sebastien 11/13/2022 10:34:17 AM(UTC)
HELP - Need script for mutiview overlays using dynamic inputs and dynamic values (3rd Party Software and Development)
by David_in_Philly 12/29/2021 6:16:41 PM(UTC)
Workaround merge transition for PIP overlays (General Discussion)
by JW 12/10/2021 5:53:32 AM(UTC)
Virtual Sets, Overlays & Layers (General Discussion)
by shampton 10/29/2021 4:45:51 AM(UTC)
Allow option for input's main position to be adjusted without affecting MultiView Overlays (Feature Requests)
by WaltG12 10/28/2021 8:22:02 AM(UTC)
Shortcut to toggle overlays and stingers in Outputs 1 - 4 (Feature Requests)
by Bob Brazner 10/15/2021 12:11:37 PM(UTC)
Repostioning overlays (General Discussion)
by MikeJustMike 6/29/2021 4:17:28 AM(UTC)
Playlist overlays jumping (General Discussion)
by howartp 6/6/2021 8:34:59 AM(UTC)
Temporarily disable overlays (General Discussion)
by Jan Hellgren 5/31/2021 4:36:45 PM(UTC)
Auto crop option to Overlays (Feature Requests)
by Josemite 5/12/2021 11:18:44 AM(UTC)
Overlays on vMix call (General Discussion)
by Lewie1999 3/7/2021 6:25:09 AM(UTC)
Show Playback Time for Video Overlays (Feature Requests)
by VVEPBrian 1/30/2021 12:06:24 AM(UTC)
Export replays with/without overlays (Feature Requests)
by Rickard_Bjorling 1/25/2021 12:57:48 AM(UTC)
