Overlays Cutting on Scene Transition
Hey fellow vMixers.
I am relatively new to the software and use it to record a podcast with multiple remote performers. Recently we are experimenting with rotating logos on screen using the Overlay functionality. When we switch scenes, however, if the overlays are still on the screen, they will clash with the new layout of inputs.
Obviously, one fix is to just make sure we fade out of the overlay before we make cut to different scenes. No problem doing so, just something that I will have to remember when directing. But, is there any way to set the overlays up so they automatically cut out on transition to a new scene?
Thanks, Ceej
Joined: 12/27/2012(UTC) Posts: 5,530  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thanks, Ceej sort of depends on how you switch the inputs , manual or shortcuts One can use triggers on the inputs one is switching to or shortcuts combined with the switching shortcut the helpfiles have a whole list of available shortcuts Also helpfull is to go through the multiple vMix video tutorials
Have been switching manually, but I will checkout the shortcuts to see if there's anything that can help this!
