cody@raceontexas.com
#1 Posted : Sunday, October 22, 2023 11:43:36 AM(UTC)
Can we get 8 overlay layers? There are MANY times I have graphics on screen that I want to keep on screen but add another and could use more then 4. Anyone else?
WaltG12
#2 Posted : Sunday, October 22, 2023 2:54:22 PM(UTC)
WaltG12
Overlays support layers. That's the general advice when this comes up.
thanks 1 user thanked WaltG12 for this useful post.
doggy on 10/22/2023(UTC)
#3 Posted : Sunday, October 22, 2023 3:03:53 PM(UTC)
I need them to be independent. I dont want to have to stack layers to do it. Would be much easier to just have 8 vs the 4 now.
WaltG12
#4 Posted : Monday, October 23, 2023 5:56:43 AM(UTC)
WaltG12
While that may be true, the key to getting feature requests taken seriously is to explain your usecase (which you really haven't done) and explain why existing options just don't cut it, which you really haven't done.
And when I say "that's the standard advice given", I mean I've seen Martin give that advice making this same request.
And I highly doubt anything you've said so far in this thread would change that, especially with last year's increase in Mix inputs giving you the ability to have independent control and gradual transitions in and out for all 10 layers of a transparent input.
And, of course, the upcoming 27 gives you more options for controlling the positioning of Mix inputs (or anything else) on those 10 layers if the overlays you want to add need PiP rather than being set for full screen.
If that's not good enough for your usecase, which it may not be, you're going to want to provide a lot more detail (or, well, any detail) as to why.
spinfold
#5 Posted : Monday, October 23, 2023 5:21:36 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
How do you achieve transitioning in of layers, please?
RichDanby
#6 Posted : Monday, October 23, 2023 8:22:00 PM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
If you need more than 4 overlays add a blank input that you show as one of the overlays, then add say 5 Mix inputs and configure these as layers on the blank input.
On the Mix inputs you can transition in any input and that will show as independently animated overlays.
#7 Posted : Monday, October 23, 2023 10:46:47 PM(UTC)
I will try this. Best option so far. It would be way to hard to explain in detail what I need.
spinfold
#8 Posted : Tuesday, October 24, 2023 4:22:27 AM(UTC)
spinfold
Ah, OK. I'm using all 15 mixes in my show already!
